BGP Vs Default Routes
rootadmin
Would like to know what is the AD as mentioned above.
Cheers
Mansur
guruprasadr
Level 7
Level 7
HI Mansur,
Pls refer to the below Link for Definition of AD & for the table lists the administrative distance default values of the protocols that Cisco supports.
http://www.cisco.com/warp/public/105/admin_distance.html#topic2
PLS Rate if HELPS
Best Regards,
Guru Prasad R
Amit Singh
Mansur,
The AD for External BGP is 20 and Internal BGP is 200. The AD for default route pointing towards the next hop ip is 1 and pointing towards the connected interface is 0.
Is that what you are looking for...
HTH,Please rate if it does.
-amit singh
guruprasadr
Level 7
Level 7
HI Mansur,
PLS Rate if HELPS
Best Regards,
Guru Prasad R
