Bgp with an fwsm
mnieuwendijk
Is it possible to use bpg peering to an isp and have an fwsm installed ?
I dont want to use a router running bgp at the outside !
Marc
8 Replies 8
Harold Ritter
It is certainly possible to do so. A couple of things to note:
1- you need to make sure you configure the eBGP session as multihop.
2- If you authenticate the session, make sure that the FWSM doesn't do randomize the initial sequence number. Otherwise, it would definitely prevent the session from coming up.
For more details, please refer to the following document:
http://www.cisco.com/en/US/tech/tk365/technologies_configuration_example09186a008009487d.shtml
Hope this helps,
Hi.
It is not that i want to use bgp trough the firewall, but running bgp at the router where the firwewall is inserted.
A little more information:
I have a isp who has running bgp.
Whe have an catalyst 6500 with an fwsm in it.
For running bgp whe have an external router who is running the bgp, and an internal connection to the 6500/firewall.
I think it is nicer to get rid of the external router.
But how i connect the bgp peering on the firewall, i have to connect the bgp peering on the 6500 becouse the fwsm has no phisical interfaces.
But how do i handle the internal and the external traffic on the same 6500.
Default gaeway is the firewall, but then through an interface at the 6500 through the isp.
So i have on the 6500 2 default gateways !!.
That is the problem.
Any good sugestions ?
Thanks for the additional information.
The FWSM itself doesn't support BGP.
As you mentioned, in order to connect to your SP you need to configure an external port (vlan).
What do you do next?
Do you want to run an multihop eBGP session from the internal network directly to the SP (not recommended).
The recommended approach is to create an external VRF that would run the BGP session to your SP and an internal VRF connected to your corporate network.
You can even run a BGP session between the two VRFs, which would allow you to detect a FW failure and fallover to another exit point in your network.
Hope this helps,
Hi.
So the best option is have an router in front of the firewall at the outside who is running the bgp session?
But just for my knowledge, is there an configuration example somewere to find on the cisco site ?
How to configure your option with the vrf ?
Thanks.
Marc
I do not necessarily think the best option is to use an external router.
At the contrary, a lot of customers are using the multi vrf approach to avoid having that external box.
The multi vrf configuration would look something like this:
ip vrf external
rd 2:1
ip vrf internal
rd 2:1
interface Vlan 10
description To the corporate network
ip vrf forwarding internal
interface Vlan 20
description To the FWSM inside interface
ip address 192.168.2.1 255.255.255.0
interface Vlan 30
description To the FWSM outside interface
ip vrf forwarding external
ip address 192.168.3.1 255.255.255.0
interface Vlan 40
description To the Service Provider
ip address 192.168.4.1 255.255.255.0
! OSPF originates the default route to the internal network if it is received via BGP
router ospf 100 vrf internal
netw 192.168.1.1 0.0.0.0 area 0
default-information originate
router bgp xxx
no synchronization
bgp log-neighbor-changes
no auto-summary
address-family ipv4 vrf internal
! Internal prefix(es) advertised to the Internet
network x.x.x.x
neighbor 192.168.3.1 remote-as xxx
neighbor 192.168.3.1 activate
no synchronization
! Per address family router-id required since both VRF would use the same RID by default. (See Note 1)
bgp router-id 2.2.2.1
exit-address-family
address-family ipv4 vrf external
neighbor 192.168.2.1 remote-as xxx
neighbor 192.168.2.1 activate
neighbor 192.168.2.1 prefix-list default-only out
neighbor 192.168.4.2 remote-as yyy
neighbor 192.168.4.2 activate
no synchronization
bgp router-id 2.2.2.2
exit-address-family
! Static route pointing at the FWSM inside interface address. Required for the iBGP session.
ip route vrf internal 192.168.3.1 255.255.255.255 Vlan20 192.168.2.2
! Static route pointing at the FWSM outside interface address. Required for the iBGP session.
ip route vrf external 192.168.2.1 255.255.255.255 Vlan30 192.168.3.2
ip prefix-list default-only description only allow default route
ip prefix-list default-only seq 10 permit 0.0.0.0/0
ip prefix-list default-only seq 20 deny 0.0.0.0/0 le 32
Note 1: The per AF RID was introduced in 12.2(33)SRA. Without this command, the BGP peers would determine that the peer RID is equal to the local RID and reject the session.
Alternatively, you can use the hidden command "bgp router-id allow-equal" that was introduced in 12.2(18)SXD1.
Let me know if you have any questions,
I forgot one thing. By default, only one Switched Virtual Interface (SVI) is allowed between the FWSM and the MSFC. In order to be able to configure more than one VLAN between the FWSM and MSFC, you need to configure the following command on the MSFC:
firewall multiple-vlan-interfaces
Hope this helps,
Thanks for the replay.
I will going to test it.
I have allready configured more then 1 vlan between the fwsm and the msfc.
Thanks a lott.
Marc
Hi, I know it's been a long time but seeing config also for FWSM would help.
Thanks.
