BGP with BDF
csco11579831
Hello everyone,
can you please help me to set up the BFD with BGP protocol between the two routers A and B, knowing that I work with static routing and ping is ok between RA and RB,
Thank you in advance!
Vignesh Rajendran Praveen
Kindly read through the below link & it would help you a lot with respect to BFD over BGP.
http://www.cisco.com/en/US/docs/ios-xml/ios/iproute_bgp/configuration/15-1sg/irg-sup-for-bfd.html#GUID-F4FF8AFE-4DA4-441B-967C-2ABE75450B87
***********Plz do rate this post if you found it helpful*************************
Thanks & Regards,
Vignesh R P
Hi Vignesh,
I have already seen it, but I did not understand this example, you have another?
Best Regards,
Hi vignesh,
you need first to setup a bfd session between the two routers
http://www.cisco.com/en/US/docs/ios-xml/ios/iproute_bgp/configuration/15-1sg/irg-sup-for-bfd.html#GUID-44D9B5FE-3402-4B25-BF41-677F9287801D
when you see the session up with "show bfd neigborhs", you can enable bfd support on bgp with:
http://www.cisco.com/en/US/docs/ios-xml/ios/iproute_bgp/configuration/15-1sg/irg-sup-for-bfd.html#GUID-C47FA8F7-B982-424B-828A-367FA34A475B
you can verify the setup with the command "show ip bgp neigbohrs X.X.X.X" , you will see a line about BFD
