BGP
asit1111990
Hello Team
i am getting following debug messages on router
BGP: 150.1.1.1 Local router is the Originator; Discard update
Can some help me figure out what exactly this measns
dmuinoorallo
Your routes are arraiving with the same ID originator that you has in your router.
If you change your BGP-ID it will be working fine.
R2(config)#router bgp 100
R2(config-router)#bgp router-id 150.1.1.2
could you check this solution?
Hi dmuinoorallo
thank you for your reply
It worked
Now try this there should not be any issue.
