Binding the internet connection
ccie_india
I have 3200 series router with two interenet connections (ISP-1 and ISP-2). is there any config to have load sharing on this two connections? Currently ISP-2 is a backup link . Pls advise.
guruprasadr
Level 7
Level 7
HI, [Pls Rate if HELPS]
Detailed description on your requirment:
Per Packet Load Balancing:
>> Will not work
Per destination based Load Balancing:
>> May work, if you are accessing some specific application like ftp, vpn access over Internet to some destinations.
Multilink Option:
Since the Link are purchased from two different ISP, will not be possible.
Available Option:
If you have owned an AS, with multiple LAN Segments means:
>> Each Segment can be destined to different ISP's using "per destination load balancing Concept"
Enable per-destination load Balancing:
Router(config)# hw-module slotnumber ip load-sharing per-destination
>> Disables per-packet and re-enables per-destination load balancing.
PLS RATE if HELPS
Best Regards,
Guru Prasad R
