Blocking Wireless Routers
Alex Li
What is the easiest method to block wireless routers from entering my network ?
My situation is users are plugging in their own wireless routers at remote locations, can I use BPDU guard for such ? I simply want
to disable the port for X minutes.
Can this be done on the 3750X series ?
Philip D'Ath
You can use a Cisco Wireless Lan Controller (WLC) with some Cisco access points.  Get an extra access point and deploy it in rogue mode.
http://www.cisco.com/c/en/us/support/docs/wireless/4400-series-wireless-lan-controllers/112045-handling-rogue-cuwn-00.html
If you have ports that a specifically only used by users, then try applying the desktop macro.
interface Gigabit0/1
  macro apply cisco-desktop
If you have Cisco phones then use:
  macro apply cisco-phone
This applies the settings recommend by Cisco for each specific model of switch.  In particular it will enable port security which will limit the number of MAC addresses allowed on the port.
