BPDU over L2TPv3
hideura
I'm connecting routers over ip network with L2TPv3.
R1 and R3 are located in a same site and R2 and R4 are in the other site.
L2TP connection between R1 and R2 looks fine but connection between R3 and R4 is not correctly tranfering bpdu.
I'm not using switch port on any routers.
1941 or 1812J has any problem with handling bpdu over l2tp?
Plus, I found some cisco document mention "promiscuous mode" but how can I set a interface to promiscuous mode?
"Because of the way in which L2TPv3 handles VLAN packets, the Ethernet interface must be configured
in promiscuous mode to capture all traffic received on the Ethernet segment attached to the router. All
frames are tunneled through the L2TP pseudowire."
R1 is 1921-01 Universal - 15.0(1)M4
R2 is 1921-02 Universal - 15.0(1)M4
R3 is 1941-01 Universal - 15.0(1)M4
R4 is 1812-01 Adv.Ent.Svc - 15.0(1)M4
R1
pseudowire-class L2TPv3
encapsulation l2tpv3
ip local interface Loopback0
pseudowire-class v201
ip local interface Loopback201
pseudowire-class v202
ip local interface Loopback202
pseudowire-class v203
ip local interface Loopback203
pseudowire-class v204
ip local interface Loopback204
interface Loopback0
ip address 1.1.1.21 255.255.255.255
ip ospf 1 area 0
ip address 1.1.1.201 255.255.255.255
ip ospf 1 area 0
ip address 1.1.1.202 255.255.255.255
ip ospf 1 area 0
ip address 1.1.1.203 255.255.255.255
ip ospf 1 area 0
ip address 1.1.1.204 255.255.255.255
ip ospf 1 area 0
interface GigabitEthernet0/0
ip address 10.102.1.1 255.255.255.0
ip ospf 1 area 0
duplex auto
speed auto
interface GigabitEthernet0/1
no ip address
duplex auto
speed auto
no keepalive
interface GigabitEthernet0/1.201
encapsulation dot1Q 201
xconnect 2.2.2.201 201 pw-class v201
interface GigabitEthernet0/1.202
encapsulation dot1Q 202
xconnect 2.2.2.202 202 pw-class v202
interface GigabitEthernet0/1.203
encapsulation dot1Q 203
xconnect 2.2.2.203 203 pw-class v203
interface GigabitEthernet0/1.204
encapsulation dot1Q 204
xconnect 2.2.2.204 204 pw-class v204
router ospf 1
router-id 1.1.1.21
log-adjacency-changes
R2
interface Loopback0
ip address 2.2.2.22 255.255.255.255
ip ospf 1 area 0
ip address 2.2.2.201 255.255.255.255
ip ospf 1 area 0
ip address 2.2.2.202 255.255.255.255
ip ospf 1 area 0
ip address 2.2.2.203 255.255.255.255
ip ospf 1 area 0
ip address 2.2.2.204 255.255.255.255
ip ospf 1 area 0
ip address 10.102.2.2 255.255.255.0
ip ospf 1 area 0
duplex auto
speed auto
no ip address
duplex auto
speed auto
no keepalive
xconnect 1.1.1.201 201 pw-class v201
xconnect 1.1.1.202 202 pw-class v202
xconnect 1.1.1.203 203 pw-class v203
xconnect 1.1.1.204 204 pw-class v204
router ospf 1
router-id 2.2.2.22
R3
interface Loopback0
ip address 3.3.3.23 255.255.255.255
ip address 3.3.3.201 255.255.255.255
ip address 3.3.3.202 255.255.255.255
ip address 3.3.3.203 255.255.255.255
ip address 3.3.3.204 255.255.255.255
ip address 10.102.3.3 255.255.255.0
duplex auto
speed auto
no ip address
duplex auto
speed auto
no keepalive
xconnect 4.4.4.201 201 pw-class v201
xconnect 4.4.4.202 202 pw-class v202
xconnect 4.4.4.203 203 pw-class v203
xconnect 4.4.4.204 204 pw-class v204
router ospf 200
network 3.3.3.0 0.0.0.255 area 0
network 10.102.3.0 0.0.0.255 area 0
R4
interface Loopback0
ip address 4.4.4.24 255.255.255.255
ip address 4.4.4.201 255.255.255.255
ip address 4.4.4.202 255.255.255.255
ip address 4.4.4.203 255.255.255.255
ip address 4.4.4.204 255.255.255.255
interface FastEthernet0
ip address 10.102.4.4 255.255.255.0
duplex auto
speed auto
interface FastEthernet1
no ip address
duplex auto
speed auto
no keepalive
interface FastEthernet1.201
xconnect 3.3.3.201 201 pw-class v201
interface FastEthernet1.202
xconnect 3.3.3.202 202 pw-class v202
interface FastEthernet1.203
xconnect 3.3.3.203 203 pw-class v203
interface FastEthernet1.204
xconnect 3.3.3.204 204 pw-class v204
router ospf 200
network 4.4.4.0 0.0.0.255 area 0
network 10.102.4.0 0.0.0.255 area 0
Thanks in advance,
0 Replies 0
