bpduguard to disable the port automatically
arun
I have enabled bpduguard to disable the port automatically whenever host flap issue occurs. And have found BPDU Guard to be very effective. But it's not working in some times. Any ideas? Thanks in advance.
Giuseppe Larosa
Hello Arun,
spanning-tree bpduguard action is triggered by the reception of an STP BPDU on the port so it is a good tool to detect unauthorized switches carried by users in offices.
if you connect an hub (that doesn't speak STP) STP bdpuguard doesn't detect it.
the presence of an hub can be inferred from the following facts:
port duplex is half duplex
multiple MAC addresses are seen on the port.
for the second you can use port security that can put the port in errordisable if more then X MAC addresses are seen on the port.
Hope to help
Giuseppe
