Break Sequence for ASR 1002-X
gbenoit83
I have made a rookie mistake while configuring my ASR 1002-X Router. I have put our network radius
server ip
and logon information to log on to the router with radius. I did not out in the emergency or local account onto the router before I put the radius information on the router. Since this router is not touching the network yet, it cannot get to the radius server. It will not connect to the network until it is configured locally.
I have tried using break commanc sequences with no success. The laptop I am using to console in doe snot have a Break key, so I cannot use the
CTRL+Break
What can I do to get into rommon mode?
Thank you
Julio E. Moisa
Control + Break
should work, also try
Control + Pause
during the booting.
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Julio E. Moisa
Control + Break
Control + Pause
during the booting.
Thank you for the sequence. There was not a break on my keyboard. So i tried
Ctrl+Pause
and it worked. Found out the special command from teh Putty drop down works as well.
Thanks Julio
