Bridge domain
james.tribble
I am converting from a 900 router to a 1111 router.  So the outside connection goes to our corp network.  I have a external DNS that is connected to the internal switch.  and they did a bvi.  moving to the new router it no longer supports BVI, so I have setup a bridge domain and a BDI inteface.  But cannot get the DNS server to talk to the inside and outside networks.  Depending on where I put the rewrite.
interface Vlan60
no ip address
service instance 60 ethernet
encapsulation default
bridge-domain 60
interface BDI60
mac-address 0001.0002.0003
ip address 10.28.208.49 255.255.254.0
ip nat outside
interface GigabitEthernet0/0/0
no ip address
negotiation auto
bridge-domain 60
interface GigabitEthernet0/1/2
Description Ex-DNS
switchport access vlan 60
switchport mode access
switchport nonegotiate
Giuseppe Larosa
Hello @james.tribble ,
you need to be consistent in configuration if you moved to bridge domains and BDI you don't need an unnumbered SVI interface Vlan 60
so:
no interface Vlan 60
then you need to configure the last interface as the previous one
do:
conf t
default interface giga0/1/2
interface giga0/1/2
bridge-domain 60
Hope to help
Giuseppe
So I tried that and it didnt work I could get to the other sites but not internal  I have attached a diagram of the network.
Shouldn't the encapsulation be:
encapsulation dot1q 60
