Free WiFi - Integration
awsdeveloper
When I go to the reception, I type in my name and whom I am meeting and the purpose of the meeting and it prints out a badge with a QR code.
What I want to achieve is it should print out the badge with a QR code and this QR code should contain the Guest WiFi credentials. This could either print out a QR code or directly the credentials for the WiFi and all users should have different credentials.
I currently have this type of setup - https://www.cisco.com/c/en/us/support/docs/security/identity-services-engine/216330-ise-self-registered-guest-portal-configu.html
What kind of setup would I need to integrate it with the machine at reception. Any links or videos would be helpful.
I am not sure if Cisco has a native solution. You probably need a 3rd party supplier like Splash Access (see link below)...
https://www.splashaccess.com/portfolio/cisco-meraki-nfc-and-qr-code-authentication/
Hello
self registration /splash screen- web authentication is mostly provided by wlcs
I would suggest you submit this post to the wlan section and i am sure the wifi gurus @Scott Fella  provide an alternative solution
Kind Regards
Paul
@paul driver https://www.splashaccess.com/portfolio/meraki-secure-webex-system/
It looks like the access code is common for anyone entering the building. We would need separate set of credentials for each user
