Bridging Mode Protocol Independent?
djmlmco
My question to the great NetPro community... When a router is in bridging mode, does it work independent of the layer 2 protocols?
snoopdoggydog
As long as you're only bridging different flavours of ethernet, then yes, as it's the same frame format regardless of whether its running 10BT, 100BT, 100FX etc
Where you're bridging to other frame types, eg token ring, it's more involved and there are complexities to getting it to work properly.
