Broken NAT
Sandip Barot
I have a cisco router 2612 where NAT is defined as below
ip nat inside source static tcp 192.168.1.63 80 175.x.x.x 80 extendable
It appears that after sometime (may be in few hours) the NAT is broken and I no longer can access the server over port 80 externally.
Only way to reconnect it is remove and add command back :
Router # no ip nat inside source static tcp 192.168.1.63 80 175.x.x.x 80 extendable
and then
Router # ip nat inside source static tcp 192.168.1.63 80 175.x.x.x 80 extendable
Can anyone please help in suggesting troubleshooting above ?
Sandip
Hello Sandip
When you say it appears nat is broken can you be more explicit?
Also can please post your config.
Res
Paul
Kind Regards
Paul
johnlloyd_13
Level 9
Level 9
hi,
this usually happens when there's too many NAT table entries and due to a low router memory.
could you monitor again and post show ip nat translations and show memory statistics history if the problem re-occurs?
perform following steps to further isolate the issue.
1. check if the nat translation is happening
2. check if there is actual traffic matching nat
3. debug the ip nat and check if translations happening(logg to buffer or with ACL)
4. check if the intended traffic hits the interface where inside nat configured(usin ACL)
5. check if the routing table points to the same exit interface where the nat outside is configured.
6. also check if there is any assymetric routing.
