Buffer failures on boot
atlewis9777
Greetings,
   I have a 2851 and a 1841 both serving as hub routers in a GRE multipoint configuration.  They are both receiving buffer misses and failures on startup.  I will post the output of show buffers below:
LAB-HUB-RTR#show buffers
Buffer elements:
     607 in free list (500 max allowed)
     9071 hits, 0 misses, 618 created
Public buffer pools:
Small buffers, 104 bytes (total 71, permanent 50, peak 71 @ 00:11:33):
     68 in free list (20 min, 150 max allowed)
     7083 hits, 74 misses, 0 trims, 21 created
     55 failures (0 no memory)
Middle buffers, 600 bytes (total 39, permanent 25, peak 39 @ 00:11:25):
     37 in free list (10 min, 150 max allowed)
     2233 hits, 42 misses, 0 trims, 14 created
     32 failures (0 no memory)
Big buffers, 1536 bytes (total 50, permanent 50):
     50 in free list (5 min, 150 max allowed)
     118 hits, 0 misses, 0 trims, 0 created
     0 failures (0 no memory)
VeryBig buffers, 4520 bytes (total 10, permanent 10):
     10 in free list (0 min, 100 max allowed)
     0 hits, 0 misses, 0 trims, 0 created
Large buffers, 5024 bytes (total 0, permanent 0):
     0 in free list (0 min, 10 max allowed)
Huge buffers, 18024 bytes (total 0, permanent 0):
     0 in free list (0 min, 4 max allowed)
I have tried increasing the small/medium buffers initial size and permanent size, however there is no change.  The buffer failures for small and medium buffers are always around this many every boot.
I have also changed the IOS versions between 12.4.24(T4) to 15.1 with no luck in stopping the failures.
Thank You for any information you can provide.
atlewis9777
Just to add to this I have also wiped the config and started with all defaults and still getting buffer failures on boot.
Any further suggestions?
Thank You
