Buffer usage is above 85% for 15 minutes
sherielbailey
Question. I have a fairly new 4510R+E Switch installed in October.  Getting a Buffer message on it.
Buffer usage is above 85% for 15 minutes.  Any Ideas?  Thanks
Output to Sho proc MEM:
sho proc mem
System memory  : 3870668K total, 940150K used, 2930520K free, 323636K kernel reserved
Lowest(b)      : 2548623864
PID     Text         Data      Stack     Heap      RSS       Total     Process
1       264          404       88        360       1676      4460      init
2       0            0         0         0         0         0         kthreadd
3       0            0         0         0         0         0         migration/0
4       0            0         0         0         0         0         sirq-high/0
5       0            0         0         0         0         0         sirq-timer/0
6       0            0         0         0         0         0         sirq-net-tx/0
7       0            0         0         0         0         0         sirq-net-rx/0
8       0            0         0         0         0         0         sirq-block/0
9       0            0         0         0         0         0         sirq-block-iopo
10      0            0         0         0         0         0         sirq-tasklet/0
11      0            0         0         0         0         0         sirq-sched/0
12      0            0         0         0         0         0         sirq-hrtimer/0
13      0            0         0         0         0         0         sirq-rcu/0
14      0            0         0         0         0         0         watchdog/0
15      0            0         0         0         0         0         desched/0
16      0            0         0         0         0         0         migration/1
17      0            0         0         0         0         0         sirq-high/1
18      0            0         0         0         0         0         sirq-timer/1
19      0            0         0         0         0         0         sirq-net-tx/1
20      0            0         0         0         0         0         sirq-net-rx/1
21      0            0         0         0         0         0         sirq-block/1
22      0            0         0         0         0         0         sirq-block-iopo
23      0            0         0         0         0         0         sirq-tasklet/1
24      0            0         0         0         0         0         sirq-sched/1
25      0            0         0         0         0         0         sirq-hrtimer/1
26      0            0         0         0         0         0         sirq-rcu/1
27      0            0         0         0         0         0         watchdog/1
28      0            0         0         0         0         0         desched/1
29      0            0         0         0         0         0         migration/2
30      0            0         0         0         0         0         sirq-high/2
31      0            0         0         0         0         0         sirq-timer/2
32      0            0         0         0         0         0         sirq-net-tx/2
33      0            0         0         0         0         0         sirq-net-rx/2
34      0            0         0         0         0         0         sirq-block/2
35      0            0         0         0         0         0         sirq-block-iopo
36      0            0         0         0         0         0         sirq-tasklet/2
37      0            0         0         0         0         0         sirq-sched/2
38      0            0         0         0         0         0         sirq-hrtimer/2
39      0            0         0         0         0         0         sirq-rcu/2
40      0            0         0         0         0         0         watchdog/2
41      0            0         0         0         0         0         desched/2
42      0            0         0         0         0         0         migration/3
43      0            0         0         0         0         0         sirq-high/3
44      0            0         0         0         0         0         sirq-timer/3
45      0            0         0         0         0         0         sirq-net-tx/3
46      0            0         0         0         0         0         sirq-net-rx/3
47      0            0         0         0         0         0         sirq-block/3
48      0            0         0         0         0         0         sirq-block-iopo
49      0            0         0         0         0         0         sirq-tasklet/3
50      0            0         0         0         0         0         sirq-sched/3
51      0            0         0         0         0         0         sirq-hrtimer/3
52      0            0         0         0         0         0         sirq-rcu/3
53      0            0         0         0         0         0         watchdog/3
54      0            0         0         0         0         0         desched/3
55      0            0         0         0         0         0         events/0
56      0            0         0         0         0         0         events/1
57      0            0         0         0         0         0         events/2
58      0            0         0         0         0         0         events/3
59      0            0         0         0         0         0         cpuset
60      0            0         0         0         0         0         khelper
63      0            0         0         0         0         0         netns
65      0            0         0         0         0         0         async/mgr
195     0            0         0         0         0         0         sync_supers
197     0            0         0         0         0         0         bdi-default
199     0            0         0         0         0         0         kblockd/0
200     0            0         0         0         0         0         kblockd/1
201     0            0         0         0         0         0         kblockd/2
202     0            0         0         0         0         0         kblockd/3
208     0            0         0         0         0         0         ata/0
209     0            0         0         0         0         0         ata/1
210     0            0         0         0         0         0         ata/2
211     0            0         0         0         0         0         ata/3
212     0            0         0         0         0         0         ata_aux
221     0            0         0         0         0         0         khubd
224     0            0         0         0         0         0         kseriod
227     0            0         0         0         0         0         kmmcd
268     0            0         0         0         0         0         rpciod/0
269     0            0         0         0         0         0         rpciod/1
270     0            0         0         0         0         0         rpciod/2
271     0            0         0         0         0         0         rpciod/3
460     0            0         0         0         0         0         khungtaskd
461     0            0         0         0         0         0         kswapd0
462     0            0         0         0         0         0         aio/0
463     0            0         0         0         0         0         aio/1
464     0            0         0         0         0         0         aio/2
465     0            0         0         0         0         0         aio/3
466     0            0         0         0         0         0         nfsiod
468     0            0         0         0         0         0         xfs_mru_cache
469     0            0         0         0         0         0         xfslogd/0
470     0            0         0         0         0         0         xfslogd/1
471     0            0         0         0         0         0         xfslogd/2
472     0            0         0         0         0         0         xfslogd/3
473     0            0         0         0         0         0         xfsdatad/0
474     0            0         0         0         0         0         xfsdatad/1
475     0            0         0         0         0         0         xfsdatad/2
476     0            0         0         0         0         0         xfsdatad/3
477     0            0         0         0         0         0         xfsconvertd/0
478     0            0         0         0         0         0         xfsconvertd/1
479     0            0         0         0         0         0         xfsconvertd/2
480     0            0         0         0         0         0         xfsconvertd/3
481     0            0         0         0         0         0         crypto/0
482     0            0         0         0         0         0         crypto/1
483     0            0         0         0         0         0         crypto/2
484     0            0         0         0         0         0         crypto/3
651     0            0         0         0         0         0         mtdblockd
655     0            0         0         0         0         0         ffe110000.spi
771     0            0         0         0         0         0         edac-poller
784     0            0         0         0         0         0         scsi_eh_0
785     0            0         0         0         0         0         usb-storage
851     108          172       88        132       664       2336      udevd
973     0            0         0         0         0         0         loop0
991     0            0         0         0         0         0         loop1
1110    0            0         0         0         0         0         loop2
1908    108          168       88        132       652       2332      udevd
2244    292          180       88        132       1404      4328      dbus-daemon
2585    24           1708      88        1328      2072      3532      klogd
2597    16           160       88        132       476       1976      portmap
2665    192          364       88        132       1120      5772      sshd
2677    144          324       88        132       836       3508      xinetd
2681    144          324       88        132       816       3508      xinetd
2711    144          324       88        132       816       3508      lockd
2712    144          324       88        132       816       3508      nfsd
2713    24           1708      88        1328      2072      3532      nfsd
2714    16           160       88        132       476       1976      nfsd
2715    192          364       88        132       1120      5772      nfsd
2716    144          324       88        132       816       3508      nfsd
2717    144          324       88        132       816       3508      nfsd
2718    0            0         0         0         0         0         nfsd
2719    0            0         0         0         0         0         nfsd
2725    76           192       88        132       344       2824      rpc.mountd
3090    772          464       88        412       948       3616      sh
3094    20           244       88        132       564       2164      inotifywait
4015    20           244       88        132       564       2164      vsi work/0
4016    20           244       88        132       564       2164      vsi work/1
4017    0            0         0         0         0         0         vsi work/2
4018    0            0         0         0         0         0         vsi work/3
4478    12           336       88        132       1784      8040      watchdog
4853    1252         10676     88        808       7292      43512     system_mgr
5081    128          43044     88        688       4824      59428     slproc
5119    132          12928     88        264       5428      38816     hwcontrol
5127    24           12808     88        164       3928      39020     ns_oir_proxy
5128    76           33444     88        296       6116      66052     profiled
5129    772          1436      88        1384      2732      4588      oom_poll.sh
5131    980          47568     88        720       9236      90644     obfld
5133    40           37540     88        296       6084      70092     consoled
5135    44           33464     88        296       6360      67484     csprovider
5137    52           50716     88        296       7004      86540     system_mgr_cli
5138    44           42376     88        584       8532      79740     plogd
5140    76           41644     88        296       6440      137964    psdprov
5141    52           50988     88        428       10020     90780     pdsd
5143    148          22240     88        296       7040      61036     gold_slave
5144    760          39084     88        568       9396      77080     osinfo-provider
5146    148          33440     88        292       6240      66208     oscore_p
5148    32           22064     88        164       4744      50040     netd
5149    60           32152     88        572       8428      73768     mem_mgmt
5150    44           21024     88        164       4780      55604     mgmte_tap
5152    1228         124368    88        11252     24772     169468    licensed
5153    304          125064    88        464       9792      165172    installer
5154    4524         146784    88        44352     106304    288556    ffm
5155    1304         152712    88        4660      22760     202744    eicored
5157    240          42240     88        756       7108      75236     dtmgr
5158    148          37616     88        164       6352      76920     cpumemd
5175    28           17940     88        164       4664      52200     liin_tap
5183    112          64464     88        2916      23384     105792    cli_agent
5185    764          122952    88        1528      13360     166472    snmp_subagent
5187    100          33444     88        296       6164      66076     erm_p
5188    72           34472     88        296       6144      67080     ngdumper_provid
5190    36           33444     88        296       6116      66012     sysinfo_p
5200    12           8708      88        164       2812      21016     fs_cmd
5218    284          67300     88        296       9840      111244    licenseagentd
5220    48           39004     88        728       7632      73560     iifd
5221    137100       939088    92        396       1227268   1333080   iosd
5222    212          51532     88        720       10072     90332     ha_mgr
6796    72           160       88        132       516       2032      tail
6844    16           360       88        132       2040      10196     epc_sm_liaison
6859    16           168       88        132       412       2176      script
6861    772          140       88        88        1428      3292      sh
6882    772          508       88        456       1792      3660      nova_sntp.sh
7140    772          1964      88        1912      3252      5116      rollback_timer.
7272    772          504       88        452       968       3656      nova_sntp.sh
7274    24           516       88        132       3840      19572     xlogger
7277    52           164       88        132       712       3152      sntp
7321    772          1952      88        1900      2424      5104      rollback_timer.
7326    24           516       88        132       3836      19572     xlogger
7331    20           244       88        132       612       2164      inotifywait
7730    108          168       88        132       624       2332      udevd
24866   108          168       88        132       624       2332      flush-8:0
26221   32           160       88        132       496       1992      sleep
0 Replies 0
