C1921 vlan configuration problems
JamieHoward123
Im fairly new to cisco, and i'm trying to configure a 1921 router for voice and data but don't seem to be getting anywhere.
I need to configure GigabitEthernt0/0 as WAN and set up X2 VLAN's,vlan1 on GigabitEthernt0/0/0 for data
and vlan100 on GigabitEthernt0/0/1 for voice.
The voice is going to a UC540 which will manage the phones and data to a separate switch but neither work at all, cant even get an IP address by connecting directly to GigabitEthernt0/0/0.
Would the UC540 be and just forget the 1921
Any pointer to what i'm missing would be great, here is my current config.
Current configuration : 2970 bytes
! Last configuration change at 18:04:06 UTC Thu Feb 4 2016
version 15.2
hostname FreshShop
boot-start-marker
boot-end-marker
enable secret 5 $1$uNn/$aFklz9tl/OXc3gChU0sRj.
no aaa new-model
ip cef
ip dhcp pool vlan1
 import all
 network 192.168.10.0 255.255.255.0
 default-router 192.168.10.254
 dns-server 78.151.239.1 78.151.235.130 8.8.8.8 8.8.4.4
no ip domain lookup
ip name-server 78.151.239.1
ip name-server 78.151.235.130
ip name-server 8.8.8.8
ip name-server 8.8.4.4
no ipv6 cef
vpdn enable
vpdn-group 1
 request-dialin
  protocol l2tp
license udi pid CISCO1921/K9 sn FGL184125M9
username fresh privilege 15 secret 5 ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
username cisco privilege 15 secret 5 ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
bridge irb
interface Embedded-Service-Engine0/0
 no ip address
 shutdown
interface GigabitEthernet0/0
 ip address dhcp
 ip access-group Internet-Inbound-ACL in
 ip nat outside
 ip virtual-reassembly in
 ip tcp adjust-mss 1460
 duplex full
 speed auto
 pppoe enable group global
 pppoe-client dial-pool-number 1
 no cdp enable
interface GigabitEthernet0/1
 no ip address
 duplex auto
 speed auto
interface GigabitEthernet0/1.1
 encapsulation dot1Q 1 native
 ip address 192.168.10.254 255.255.255.0
interface GigabitEthernet0/1.100
 encapsulation dot1Q 3
 ip address 10.1.1.254 255.255.255.0
interface GigabitEthernet0/0/0
 switchport mode trunk
 no ip address
interface GigabitEthernet0/0/1
 switchport access vlan 100
 no ip address
interface GigabitEthernet0/0/2
 no ip address
interface GigabitEthernet0/0/3
 no ip address
interface Vlan1
 description Data
 no ip address
 ip nat inside
 bridge-group 1
 bridge-group 1 spanning-disabled
interface Vlan100
 no ip address
 ip nat inside
interface Dialer0
 ip address negotiated
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 ip mtu 1432
 ip nat outside
 encapsulation ppp
 dialer pool 1
 ppp authentication chap callin
 ppp chap hostname ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
 ppp chap password ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
 no cdp enable
interface Dialer1
 no ip address
interface BVI1
 description Bridge to Internal Network
 ip nat inside
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 1 interface Dialer1 overload
ip route 0.0.0.0 0.0.0.0 Dialer1
ip route 0.0.0.0 0.0.0.0 dhcp
control-plane
bridge 1 route ip
line con 0
 logging synchronous
line aux 0
line 2
 no activation-character
 no exec
 transport preferred none
 transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
 stopbits 1
line vty 0 4
 login
 transport input all
scheduler allocate 20000 1000
end
Jon Marshall
There seems to be a lot of extra configuration but if the clients can't even get an IP have you connected the switch to the gi0/1 interface ?
Because that is where it needs to be connected to and the switch port should be configured as trunk link.
Jon
