c2801 problem with booting
ip912klp03
Hi all. I've c2801 and after powering on router no boot automatically, each time i've to run it by command: boot.
Below is the bootup message that appears:
System Bootstrap, Version 12.3(8r)T8, RELEASE SOFTWARE (fc1)
Copyright (c) 2004 by cisco Systems, Inc.
PLD version 0x10
GIO ASIC version 0x127
c2801 processor with 262144 Kbytes of main memory
Main memory is configured to 64 bit mode with parity disabled
Readonly ROMMON initialized
rommon 1 >
Could you tell me how to fix this problem?
ankbhasi
Hi Friend,
I believe you config register value is not set correctly or your boot statement is not defined properly.
Can you issue a boot statement again and check the boot statement if it is not correctly set then confiure it to
boot system flash:
Make sure you enter correct file name when are in config mode.
Also once booted up please check if the config register value is 0x2102 or not and you can check that giving "sh version" command.If it is not 0x2102 set it to the same issuing command
router(config)#config-reg 0x2102
Ankur
Thanks for your help.
It was not correct register vlue (0x0). After change on 0x2102 it's booting automatically.
Gregory
