(C7200-IPBASE-M), Version 12.4(4)XD is not supporting BGP Protocol!!
Dr.X
Level 2
Level 2
hi ,
i bought cisco 7206 router and want to use bgp protocol . ,note that my ios is not supporting bgp ,
here is the error:
router(config)#router bgp 1111
Protocol not in this image
router(config)#
but i have another router which is used as bgp router ,
my question is , can i copy the ios of the router which is using bgp to my  new router ??
hint both my routers are 7206
here is the config of my new router
router#sh version
Cisco IOS Software, 7200 Software (C7200-IPBASE-M), Version 12.4(4)XD, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2006 by Cisco Systems, Inc.
Compiled Tue 25-Apr-06 11:12 by pwade
ROM: System Bootstrap, Version 12.4(12.2r)T, RELEASE SOFTWARE (fc1)
BOOTLDR: Cisco IOS Software, 7200 Software (C7200-KBOOT-M), Version 12.4(4)XD, RELEASE SOFTWARE (fc1)
NS-Gateway uptime is 20 minutes
System returned to ROM by reload at 12:37:52 UTC Tue Mar 6 2001
System image file is "disk2:c7200p-ipbase-mz.124-4.XD.bin"
Last reload reason: Reload Command
Cisco 7206VXR (NPE-G2) processor (revision A) with 917504K/65536K bytes of memory.
Processor board ID 26790100
MPC7448 CPU at 1666Mhz, Implementation 0, Rev 2.2
6 slot VXR midplane, Version 2.9
Last reset from power-on
--More--
*Mar  6 12:59:38.923: %SYS-5-CONFIG_I: Configured from console PCI bus mb1 (Slots 1, 3 and 5) has a capacity of 600 bandwidth points.
Current configuration on bus mb1 has a total of 0 bandwidth points.
This configuration is within the PCI bus capacity and is supported.
PCI bus mb2 (Slots 2, 4 and 6) has a capacity of 600 bandwidth points.
Current configuration on bus mb2 has a total of 0 bandwidth points.
Please refer to the following document "Cisco 7200 Series Port Adaptor
Hardware Configuration Guidelines" on Cisco.com <http://www.cisco.com>
for c7200 bandwidth points oversubscription and usage guidelines.
1 FastEthernet interface
3 Gigabit Ethernet interfaces
2045K bytes of NVRAM.
254464K bytes of ATA PCMCIA card at slot 2 (Sector size 512 bytes).
65536K bytes of Flash internal SIMM (Sector size 512K).
*****************************8
here is the config of  my old router which is working as bgp router
NS-Gateway#sh version
Cisco IOS Software, 7200 Software (C7200P-ADVENTERPRISEK9-M), Version 12.4(24)T4, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Fri 03-Sep-10 12:11 by prod_rel_team
BOOTLDR: Cisco IOS Software, 7200 Software (C7200P-KBOOT-M), Version 12.4(4)XD5, RELEASE SOFTWARE (fc1)
NS-Gateway uptime is 2 weeks, 6 days, 2 hours, 45 minutes
System returned to ROM by reload at 01:04:17 UTC Wed Dec 1 1999
System image file is "disk2:c7200p-adventerprisek9-mz.124-24.T4.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 7206VXR (NPE-G2) processor (revision A) with 1966080K/65536K bytes of memory.
Processor board ID 13252317
6 slot VXR midplane, Version 2.0
250880K bytes of ATA PCMCIA card at slot 2 (Sector size 512 bytes).
Hello Ahmed,
Assuming the new IOS will not be able to boot and run smoothly, you should always be able to send the break sequence from your terminal while (any) IOS is booting, and in the ROMMON, you should be able to use the boot command to boot a selected IOS.
This document describes the procedure:
http://www.cisco.com/en/US/products/hw/routers/ps359/products_tech_note09186a00800a750e.shtml
Best regards,
Peter
13 Replies 13
Peter Paluch
Hello Ahmed,
I am afraid the router is telling the truth. The IP Base feature set does not contain the support for BGP. You need at least SP SERVICES or Advanced Security feature set to have the BGP support.
Try the Cisco Feature Navigator tool at http://cisco.com/go/fn to find out exactly what feature set contains the functions you need.
Best regards,
Peter
hi ,
yes the router is saying the truth .
look down at my post ,
i said that i have another router which has an ios updated ,
my question is , could i copy this ios to my new router ???
i didnt try to do before and afraid from risk
regards
hi ,
i loaded  the ios which support bgp to my new router and i just need to type the command below :
##boot system flash bgp-ios
but im
hesitant
to do it , thats why im asking ,
is there any risk of loading the new ios  ???
regards
Hello Ahmed,
The two routers do not appear to have the same amount of RAM. The 7200 router running the IPBASE image appears to have 960MB RAM, however, the Advanced Enterprise Services image requires at least 1024MB RAM (this fact can be confirmed in the Feature Navigator tool). I am afraid it will not be able to run it on your new 7200 router. You need an image with smaller memory requirement.
Best regards,
Peter
hi mr peter ,
in my bootflash i have two images, the default one , and the new one which support bgp
assume the new ios didnt work ,
wt i need to do then ,  to tell the router to load the  default ios ???
regards
Hello Ahmed,
Best regards,
Peter
hi peter ,
it seems that it faild to load the  new ios
i typed the command
boot system flash
c7200p-kboot-mz.124-4.XD5-Gateway.bin
but it faile
here is the message of console during startup
Readonly ROMMON initialized
Self decompressing the image : ################################################################################################################################ [OK]
%SYS-6-READ_BOOTFILE_FAIL: tftp://255.255.255.255/flash:c7200p-kboot-mz.124-4.XD5-Gateway.bin File read failed -- Timed out.
%Error opening tftp://255.255.255.255/flash:c7200p-kboot-mz.124-4.XD5-Gateway.bin (Timed out)
%SYS-6-BOOT_MESSAGES: Messages above this line are from the boot loader.
Self decompressing the image : ############################################################################################################################################################################################################################################# [OK]
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
here is the commad  of boot flash
Gateway#sh bootflash:
-#- ED ----type---- --crc--- -seek-- nlen -length- ---------date/time--------- name
1   .. image        31E6C0CD  80D9F8   28  7919992 Apr 27 2011 07:32:31 +00:00 c7200p-kboot-mz.124-4.XD.bin
2   .. config       AF4F98C5  80F580   16     6917 Mar 6 2001 12:49:06 +00:00 ns-gateway-confg
3   .. image        D9C0D081  F9E9F4   37  7926772 Mar 6 2001 13:13:48 +00:00 c7200p-kboot-mz.124-4.XD5-Gateway.bin
49681932 bytes available (15854068 bytes used)
did i forgot to something ????
regards
Hi Ahmed,
The IOS image name on the previous 7200 is "c7200p-adventerprisek9-mz.124-24.T4.bin" - I do not see such image in your new 7200 router. Did you rename it during the copy?
Best regards,
Peter
yes i renamed it to
c7200p-kboot-mz.124-4.XD5-Gateway.bin ===> this is the new iso which support bgp
u can see it in     #sh bootflash  command       above
wts the next step
regards
Hello Ahmed,
Renaming IOS images is a bad practice - please never do that. Rename the image back to its original name.
Try using the exact line in your configuration:
boot system bootflash:c7200p-adventerprisek9-mz.124-24.T4.bin
Then, after entering this command in the global config mode, write the configuration using the copy run start command, and then reload the router. Optionally, try running the show boot or show bootvar command before reboot and post the output here: this command should print out the settings of boot variables influencing which IOS will be loaded.
Best regards,
Peter
hi , ive done every thing but it seems didnt work
here is the startup console message
*Mar  6 15:06:24.647: %SYS-5-CONFIG_I: Configured from console by console
[confirm]
*Mar  6 15:06:27.363: %SYS-5-RELOAD: Reload requested by console. Reload Reason: Reload Command.
Copyright (c) 2006 by cisco Systems, Inc.
Socket jumper: not present Failsafe jumper: present = normal
FPGA revision 0x00000026
C7200 platform with 1046528 Kbytes of main memory
%SYS-6-READ_BOOTFILE_FAIL: tftp://255.255.255.255/flash:c7200p-kboot-mz.124-4.XD5.bin File read failed -- Timed out.
%Error opening tftp://255.255.255.255/flash:c7200p-kboot-mz.124-4.XD5.bin (Timed out)
           cisco Systems, Inc.
Image text-base: 0x0000A320, data-base: 0x01718000
Press RETURN to get started!
as u see , it fialed to load the new ios and retured loading the defualt ios !!!!!!!!!!
am i missleading something ??
as u see , the ios files seems unreadable , im sure i get it from ld router with no troubles !!!!
here is list of my configs
NS-Gateway#sh bo
NS-Gateway#sh bootf
NS-Gateway#sh bootflash:
3   .D image        D9C0D081  F9E9F4   37  7926772 Mar 6 2001 13:13:48 +00:00 c7200p-kboot-mz.124-4.XD5-Gateway.bin
4   .D image        D9C0D081 172DE68   37  7926772 Mar 6 2001 15:00:13 +00:00 c7200p-kboot-mz.124-4.XD5-Gateway.bin
5   .. image        D9C0D081 1EBD2DC   29  7926772 Mar 6 2001 15:05:14 +00:00 c7200p-kboot-mz.124-4.XD5.bin
33828132 bytes available (31707868 bytes used)
NS-Gateway#sh bo
NS-Gateway#sh bootv
NS-Gateway#sh bootvar
BOOT variable = c7200p-kboot-mz.124-4.XD5-Gateway.bin,1;c7200p-kboot-mz.124-4.XD5.bin,1;
CONFIG_FILE variable does not exist
BOOTLDR variable does not exist
WARM_REBOOT variable = FALSE
does that mean that the ios is not supported ???? or it is corrupted ???????????
regards
hi , it seems i have a probelm
note the ios is in disk 2 , but when i get it, i get it from bootflash !!!
this seems to be my mistake
Hello Ahmed,
Try to find out into which filesystem exactly did you copy the IOS. You may use the show file systems command to find out which filesystems are recognized on your 7200. The boot system command will need to know the exact filesystem where the IOS is loaded.
If nothing else helps, you may try to delete the existing IOS and leave only the new IOS in place.
Best regards,
Peter
