Cisco 887VA port mapping issue
delprofundo
I'm pretty new to IOS configuration and am having some difficulties mapping some external ports to hosts on the inside of the network.
I have gone through the steps that I expected would work and the hosts on the inside of the network can connect to the outside world and the results of internal to external mappings are present as expected while viewing the debug information.
What is also interesting, as depicted here, is that the static mappings are showing in the transactions table:
tcp 1XX.1XX.1XX.1XX:19770  2YY.2YY.2YY:3389    ---                   --- These are as configured.
When I attempt to connect to the address using the external port I am not seeing any evidence in the logs that point to the attempted translation being made.
Here is my complete config:
version 15.1
no service pad
service password-encryption
hostname broute1
boot-start-marker
boot-end-marker
logging buffered 65535
logging console informational
no aaa new-model
memory-size iomem 10
clock timezone ESTime 10 0
ip source-route
ip cef
no ip bootp server
ip domain name ninterface.com
ip name-server IPADDRESS DNS
ip inspect name CBAC appleqtc
ip inspect name CBAC dns
ip inspect name CBAC esmtp
ip inspect name CBAC http
ip inspect name CBAC https
ip inspect name CBAC ftp
ip inspect name CBAC h323
ip inspect name CBAC isakmp
ip inspect name CBAC l2tp
ip inspect name CBAC icmp
ip inspect name CBAC imap
ip inspect name CBAC imaps
ip inspect name CBAC ftps
ip inspect name CBAC ntp
ip inspect name CBAC sip
ip inspect name CBAC sip-tls
ip inspect name CBAC ssh
ip inspect name CBAC tcp
ip inspect name CBAC udp
login block-for 300 attempts 4 within 60
login delay 7
login quiet-mode access-class aclQuietMode
login on-failure log
no ipv6 cef
license udi pid CISCO887VA-SEC-K9 sn XXXXXXXXXX
archive
log config
  hidekeys
username PERSON privilege 15 secret 4 BLAHBLAH
controller VDSL 0
operating mode adsl2 annex A
ip ssh version 2
interface Loopback0
no ip address
interface Ethernet0
no ip address
shutdown
no fair-queue
interface ATM0
description --- Internode ADSL ----
no ip address
no ip route-cache
load-interval 30
no atm ilmi-keepalive
interface ATM0.1 point-to-point
no ip route-cache
pvc 8/35
  tx-ring-limit 3
  encapsulation aal5snap
  pppoe-client dial-pool-number 1
interface FastEthernet0
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface Vlan1
description Management Interface
ip address INTERNALADDRESS 255.255.255.0
ip nat inside
ip virtual-reassembly in
no ip route-cache cef
ip tcp adjust-mss 1420
interface Dialer0
no ip address
shutdown
no cdp enable
interface Dialer1
description -----INTERNODE ADSL------
mtu 1492
ip address negotiated
ip access-group 103 in
no ip redirects
no ip unreachables
no ip proxy-arp
ip mtu 1460
ip nat outside
ip inspect CBAC out
encapsulation ppp
ip tcp adjust-mss 1452
dialer pool 1
dialer-group 1
ppp chap hostname INTERNETUSERNAME
ppp chap password 7 INTERNETPASSWORD
ppp ipcp dns request accept
no cdp enable
ip forward-protocol nd
no ip http server
no ip http secure-server
ip dns server
ip dns server
ip nat inside source static tcp 2YY.2YY.2YY 3389 interface Dialer1 19770
ip nat inside source static tcp 2YY.2YY.2YY 22 interface Dialer1 19771
ip nat inside source static tcp 2YY.2YY.2YY 5000 interface Dialer1 5000
ip nat inside source static tcp 2YY.2YY.2YY873 interface Dialer1 873
ip nat inside source static tcp 2YY.2YY.2YY 3389 interface Dialer1 31313
ip nat inside source static tcp 2YY.2YY.2YY 3389 interface Dialer1 19450
ip nat inside source list NAT-ACL interface Dialer1 overload
ip route 0.0.0.0 0.0.0.0 Dialer1
ip access-list standard acINAT
ip access-list standard aclQuietMode
permit INTERNALRANGE 0.0.0.255
ip access-list extended NAT-ACL
permit ip INTERNALRANGE  0.0.0.255 any
ip access-list extended aclNat
logging trap debugging
access-list 43 permit INTERNALRANGE  0.0.0.255
access-list 103 permit tcp host 0.0.0.0 host STATICGLOBAL eq EX-PORT
access-list 103 permit icmp any any
dialer-list 1 protocol ip permit
no cdp run
route-map rmNatIn2Out permit 10
match ip address aclNat
control-plane
alias exec t10 term len 0
alias exec ps show process cpu
alias exec top show process cpu sort 5m | exc1 (0.00% 0.00% 0.00%)
alias exec version show version | include image
alias exec uptime show version | include uptime|ROM[^:]|restarted
alias exec hist show process cpu history
line con 0
login local
transport output ssh
line aux 0
transport output all
line vty 0 2
access-class aclNat in
exec-timeout 20 0
privilege level 15
login local
transport input ssh
line vty 3 4
access-class aclQuietMode in
exec-timeout 20 0
privilege level 15
login local
transport input ssh
scheduler max-task-time 5000
sntp server 192.231.203.132
end
Yep its a terrible hackjob and I am sure there are a few commands that dont belong any more but I'm perplexed as to what I have missed.
Can anyone help point me in the right direction?
Thanks!
Bruno
paolo bevilacqua
Under dialer 1 remove ip access-group, ip inspect, ip mtu, and ip tcp mss adjust.
The latter has to be 1452 under vlan 1 only.
That shuld be enough.
paolo bevilacqua
Wow, Paolo thank you so much! That got it going right away, now just to work out why i thought all that should stay!
Thanks again!
B
The longer you work with Cisco, the less commands you will use.
Thank you for the nice rating and good luck!
