C870 booting Problem
Hello Friends,
I have a cisco 870 router which ends up in the ROMMON mode after starting. It continues in the rommon mode and I am unable to type any word  as it keeps on increasing the ROMMON mode number as rommon1, rommon2, rommon3...........rommonN. When I try to enter anything say DIR, it  doesn't accept any alphabet and types some special characters.
Kindly check the output below :
System Bootstrap, Version 12.3(8r)YI4, RELEASE SÿFTWARE
Copyright (c) 2006 by cisco Systems, Inc.
C870 series (Board ID: 1-148) platform with 13107ÿ Kbytes of main memory
rommon 1 > iOriai  C  !!C1?
monitor: command "iOriai  C  !!C1? " not fouÿd
rommon 2 >
rommon 3 > Ojn.larg^ kc?!  ?
monitor: command "Ojn.larg^ kc?!  ?" not fÿund
rommon 4 >  ngs_
monitor: command "ngs_" not found
rommon 5 > ? ?gj
monitor: command "? ?gj" not found
rommonÿ6 >
rommon 7 >
rommon 7 >
Kidly help to understand , whats the problem ?
7 Replies 7
Leo Laohoo
Can I ask if you can please post the entire bootup process?
Dear Leo,
This is the complete process from the moment I restarted the router which have been captured .
rommon 2 >
rommon 4 >  ngs_
rommon 5 > ? ?gj
rommonÿ6 >
rommon 7 >
rommon 7 >
rommon 7 >
rommon 7 >
rommon 7 >
rommon 7 >
rommon 7 > Krdr
monitor: command "Krdr" not found
rommon 8 >
rommon 8 >
rommon 8 > g fikr
monitor: command "g fikr" not found
rommon 9ÿ>
rommon 10 > C
monitor: command "C" not found
rommon 11 >
rommon 11 >
rommon 11 >
rommon 11 >
rommon 11 >
rommon 11 >
rommon 11 >
rommon 11 >
rommon 11 > x
monitor: command "x" not found
rommon 12 >
rommon 12 > 5
monitor: command "5" not found
rommon 13 >
rommon 13 > }
monitor: command "}" not found
rommon 14 >
rommon 15 >
rommon 15 > _k
monitor: command "_k" not found
rommon 16 >
rommon 16 >
rommon 16 > k
No stack trace available
rommon 17 >
rommon 17 >
Hi Mr. Arif,
Use this command in rommon if you are having valid IOS in it.
dev (this will check the flash or disk installed)
then finding the device you were having in it, try
dir or dir flash, check the valid ios if it is  there:
then put boot command or boot flash:image name
If the router bootsup sucessfully check the config-register value;
If you don't have IOS previously installed try tftp upload of IOS
http://www.cisco.com/en/US/products/hw/routers/ps259/products_tech_note09186a008015bf9e.shtml
BR// SS
Thanks Mr. Sanjay,
I am unable to type anything in the rommon mode. If i try to type dev 's first alphabet say 'd' there appears some other character. When i press enter key  it gives "command not found"  increments like from rommon3 to rommon4. I have checked this on different laptops and PC's but same problem exist. The problem is I am unable to type any command in rommon. When I press backspace to delete the wrongly typed letter it keeps on inputing some other letters sometimes and sometimes it deletes the rommon word also.
Mr. Arif,
While logging via console /hyperterminal try different console bits rate. Right now u are using 9600 default setting. Try using different baud rate.
For Ref:
Load Rate (Baud)
Approximate Time (Minutes)
2400
48
9600
12
19200
6
38400
BR// Sanjay
Hmmm ... Can you try other computer or client?
Thanks Sanjay & Leo,
The problem is solved.  The moments i used the  different cable for console connection it worked fine.
  The console cable which I had used for C870 is working fine on other routers but  it is not working on C870 and I cant understand why.
Anyway's I am happy , it is working as I needed the router tomorrow.
