C881 Nano Cube
Eddie Rodriguez
The C881 will soon be EOS, and the replacement is the ISR921 but I don't see that the ISR921 supports Nano Cube, does anyone know if CUBE will be supported on the ISR900.
it is available on the platforms listed in Table 2 of the attached document. The ISR900 does not support it...
https://www.cisco.com/c/en/us/products/collateral/unified-communications/unified-border-element/data-sheet-c78-729692.html#Router-Platform-Support
Thanks for your quick reply, but issue is price, the 4321 is more than the 881.
