[Packet Tracer 7.2.1]Completely delete VLAN and/or SVI from 2911 Router
GillverK
Please note that "no vlan 2" and commands of that nature do not seem to work on the 2911 Router
After attaching an HWIC-4ESW module to the 2911 Router I set up an interface VLAN and assigned an IP to the interface using the commands:
interface vlan 2
ip address 10.10.10.2 255.255.255.0
no shut
exit
interface f0/3/1
switchport mode access
switchport access vlan 2
no shut
end
I then moved the interface to VLAN 1 and deleted thought I deleted the VLAN by doing:
interface f0/3/1
switchport access vlan 1
exit
no interface vlan 2
end
But when I do the following command on the 2911 Router Vlan 2 still seems to show up:
# show vlan brief
VLAN     NAME             STATUS       PORTS
1            VLAN001        ACTIVE         F0/3/1
2            VLAN002        ACTIVE
# show vlan id 2
2            VLAN002        ACTIVE
Can anyone tell me why this is and how to actually delete the vlan on the router? Is the only way to delete vlan .dat?
luis_cordova
Hi @GillverK ,
Effectively, in this device the way to delete all vlan is by deleting the vlan.dat file and restarting the device.
Router#delete vlan.dat
Confirm
Router#reload
Confirm
If you want to delete a single vlan, you must do it in the vlan database
Router#vlan database
Router(vlan)#no vlan 2
Router(vlan)#exit
luis_cordova
Hi @GillverK ,
Confirm
Router#reload
Confirm
Router(vlan)#exit
I see.
I avoided "vlan database" because the device issued a warning that I should do anything regarding VLANS in "config mode" because "vlan database" was being deprecated.
Thanks so much luis_cordova. Much appreciated.
