c881 PBR NAT
Ruslan Kopenkin
Got a task to NAT some traffic through remote c881. IPsec between devices works fine.
sh run
Building configuration...
Current configuration : 5824 bytes
! Last configuration change at 17:22:39 UTC Thu Sep 6 2018 by admin
version 15.6
no service pad
service password-encryption
hostname XXX
boot-start-marker
boot system flash:c800-universalk9-mz.SPA.156-3.M3.bin
boot-end-marker
aaa new-model
aaa authentication login default local
aaa session-id common
clock timezone UTC 5 0
no ip source-route
ip dhcp excluded-address 192.168.6.1 192.168.6.10
ip dhcp pool XXX
 network 192.168.6.0 255.255.255.0
 default-router 192.168.6.1
 dns-server 192.168.5.6 192.168.5.7 193.232.88.17 194.84.23.125
 domain-name XXX
ip dhcp pool XXX-iptel
 network 10.10.2.0 255.255.255.0
 default-router 10.10.2.1
 domain-name XXX-IPTEL
 option 66 ascii 10.10.12.2
ip dhcp pool hp1214
 host 192.168.6.11 255.255.255.0
 client-identifier 0144.1ea1.302e.fa
 client-name hp1214
no ip bootp server
ip domain name otst.local
ip inspect name INSPECT-OUT dns
ip inspect name INSPECT-OUT icmp router-traffic
ip inspect name INSPECT-OUT ntp
ip inspect name INSPECT-OUT tcp router-traffic
ip inspect name INSPECT-OUT udp router-traffic
ip inspect name INSPECT-OUT http
ip inspect name INSPECT-OUT https
ip inspect name INSPECT-OUT ftp
ip cef
no ipv6 cef
cts logging verbose
license udi pid C881-K9 sn
license accept end user agreement
license boot module c800 level advipservices
username admin privilege 15 secret 5
redundancy
crypto isakmp policy 5
 encr aes 256
 authentication pre-share
 group 14
 lifetime 1000
crypto isakmp policy 10
 encr aes 256
 group 2
crypto isakmp key XXX address YYY
crypto ipsec transform-set cryptoset-YYY esp-aes 256 esp-sha-hmac
 mode tunnel
crypto map ipsec-YYY 10 ipsec-isakmp
 set peer YYY
 set transform-set cryptoset-YYY
 match address crlist-YYY
interface Loopback0
 ip address 1.1.1.1 255.255.255.0
 ip nat inside
 ip virtual-reassembly in
interface FastEthernet0
 no ip address
 shutdown
interface FastEthernet1
 no ip address
 shutdown
interface FastEthernet2
 description << IPT-WAN >>
 switchport mode trunk
 no ip address
interface FastEthernet3
 description << LAN >>
 no ip address
interface FastEthernet4
 description << WAN >>
 ip address XXX 255.255.255.252
 ip access-group FIRAWALL in
 no ip redirects
 no ip proxy-arp
 ip nat outside
 ip inspect INSPECT-OUT out
 ip verify unicast reverse-path
 ip policy route-map iptnat
 duplex auto
 speed auto
 no cdp enable
 crypto map ipsec-eka
interface Vlan1
 description <<< LAN >>>
 ip address 192.168.6.1 255.255.255.0
 ip nat inside
interface Vlan2
 description << IPT LAN >>
 ip address 10.10.2.1 255.255.255.0
interface Vlan532
 ip address 172.16.59.21 255.255.255.252
 ip nat outside
ip forward-protocol nd
no ip http server
no ip http secure-server
ip dns server
ip nat inside source list NAT interface FastEthernet4 overload
ip nat inside source list iptnat interface Vlan532 overload
ip route 0.0.0.0 0.0.0.0 XXX
ip ssh time-out 60
ip ssh authentication-retries 2
ip ssh version 2
ip ssh server algorithm encryption aes128-ctr aes192-ctr aes256-ctr
ip ssh client algorithm encryption aes128-ctr aes192-ctr aes256-ctr
ip access-list extended FIREWALL
 permit tcp any any eq 22
 permit esp host YYY host XXX
 permit udp host YYY host XXX eq isakmp
ip access-list extended NAT
 deny   ip 192.168.6.0 0.0.0.255 192.168.5.0 0.0.0.255
 deny   ip 192.168.6.0 0.0.0.255 10.0.0.0 0.0.0.255
 deny   ip 192.168.6.0 0.0.0.255 192.168.7.0 0.0.0.255
 deny   ip 10.10.2.0 0.0.0.255 10.10.12.0 0.0.0.255
 deny   ip 10.10.2.0 0.0.0.255 10.0.0.0 0.0.0.255
 deny   ip 172.16.59.20 0.0.0.3 10.10.12.0 0.0.0.255
 permit ip 192.168.6.0 0.0.0.255 any
ip access-list extended crlist-YYY
 permit ip 192.168.6.0 0.0.0.255 192.168.5.0 0.0.0.255
 permit ip 192.168.6.0 0.0.0.255 10.0.0.0 0.0.0.255
 permit ip 192.168.6.0 0.0.0.255 192.168.7.0 0.0.0.255
 permit ip 10.10.2.0 0.0.0.255 10.10.12.0 0.0.0.255
 permit ip 10.10.2.0 0.0.0.255 10.0.0.0 0.0.0.255
 permit ip 172.16.59.20 0.0.0.3 10.10.12.0 0.0.0.255
ip access-list extended iptnat
 permit ip 10.10.12.0 0.0.0.255 172.16.59.20 0.0.0.3
ipv6 ioam timestamp
route-map iptnat permit 10
 match ip address iptnat
 set int loopback 0
access-list 101 permit icmp 172.16.59.20 0.0.0.3 10.10.12.0 0.0.0.255
access-list 101 permit icmp 10.10.12.0 0.0.0.255 172.16.59.20 0.0.0.3
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
 vstack
line con 0
 no modem enable
line aux 0
line vty 0 4
 privilege level 15
 password 7
 transport input telnet ssh
 escape-character 3
line vty 5 15
 transport input none
 escape-character 3
scheduler allocate 20000 1000
ntp update-calendar
end
Expect here: traffic matching access-list iptnat routed to Loopback0 with nat inside and went througth Vlan532 with nat outside. But debug ip pac 101 shows routing accordig global table
*Sep  6 12:56:53.724: IP: s=10.10.12.1 (FastEthernet4), d=172.16.59.22, len 100, input feature, Common Flow Table(5), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
*Sep  6 12:56:53.724: IP: s=10.10.12.1 (FastEthernet4), d=172.16.59.22, len 100, input feature, Stateful Inspection(8), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
*Sep  6 12:56:53.724: IP: s=10.10.12.1 (FastEthernet4), d=172.16.59.22, len 100, input feature, Stateful Inspection On Cypher Text(9), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
*Sep  6 12:56:53.724: IP: s=10.10.12.1 (FastEthernet4), d=172.16.59.22, len 100, input feature, Virtual Fragment Reassembly(39), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
*Sep  6 12:56:53.724: IP: s=10.10.12.1 (FastEthernet4), d=172.16.59.22, len 100, input feature, Access List(47), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
*Sep  6 12:56:53.724: IP: s=10.10.12.1 (FastEthernet4), d=172.16.59.22, len 100, input feature, IPSec input classification(55), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
*Sep  6 12:56:53.724: IP: s=10.10.12.1 (FastEthernet4), d=172.16.59.22, len 100, input feature, Virtual Fragment Reassembly After IPSec Decryption(57), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
*Sep  6 12:56:53.724: IP: s=10.10.12.1 (FastEthernet4), d=172.16.59.22, len 100, input feature, uRPF(60), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
*Sep  6 12:56:53.724: IP: s=10.10.12.1 (FastEthernet4), d=172.16.59.22, len 100, input feature, Common Flow Table Post VPN(68), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
*Sep  6 12:56:53.724: IP: s=10.10.12.1 (FastEthernet4), d=172.16.59.22, len 100, input feature, Stateful Inspection On Clear Text(77), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
*Sep  6 12:56:53.724: IP: s=10.10.12.1 (FastEthernet4), d=172.16.59.22, len 100, input feature, NAT Outside(92), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
*Sep  6 12:56:53.724: IP: s=10.10.12.1 (FastEthernet4), d=172.16.59.22, len 100, input feature, Policy Routing(103), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
*Sep  6 12:56:53.724: IP: s=10.10.12.1 (FastEthernet4), d=172.16.59.22, len 100, input feature, MCI Check(109), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
*Sep  6 12:56:53.724: IP: s=10.10.12.1 (FastEthernet4), d=172.16.59.22 (Vlan532), len 100, output feature, Post-routing NAT Outside(26), rtype 1, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
*Sep  6 12:56:53.724: IP: s=10.10.12.1 (FastEthernet4), d=172.16.59.22 (Vlan532), len 100, output feature, Common Flow Table(29), rtype 1, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
*Sep  6 12:56:53.728: IP: s=10.10.12.1 (FastEthernet4), d=172.16.59.22 (Vlan532), len 100, output feature, Stateful Inspection(30), rtype 1, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
*Sep  6 12:56:53.728: IP: s=10.10.12.1 (FastEthernet4), d=172.16.59.22 (Vlan532), len 100, output feature, Firewall (NAT)(50), rtype 1, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
*Sep  6 12:56:53.728: IP: s=10.10.12.1 (FastEthernet4), d=172.16.59.22 (Vlan532), len 100, output feature, Firewall (inspect)(56), rtype 1, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
*Sep  6 12:56:53.728: IP: s=10.10.12.1 (FastEthernet4), d=172.16.59.22 (Vlan532), len 100, output feature, NAT ALG proxy(63), rtype 1, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
*Sep  6 12:56:53.728: IP: s=10.10.12.1 (FastEthernet4), d=172.16.59.22 (Vlan532), g=172.16.59.22, len 100, forward
*Sep  6 12:56:53.728: IP: s=10.10.12.1 (FastEthernet4), d=172.16.59.22 (Vlan532), len 100, sending full packet
Tried to set up next-hop with no luck.
Thanks for any help
check if the bug below applies.
NAT PBR is not working with set ip next hop when CEF enabled
CSCtw57637
Description
Symptom:
On Cisco 880/890 Series router, IP CEF with PBR "set ip next-hop" will not work.
Conditions:
Router-800(config-route-map)#do sh route
route-map RM-Nat-on-a-stick, permit, sequence 50
Match clauses:
ip address (access-lists): PBR-Nat-on-a-stick
Set clauses:
ip next-hop 172.16.12.2 <=== this IP address is not configured on any devices, rather it falls under the same subnet as the Loopback ip address of the NAT-on-a-stick router
Nexthop tracking current: 0.0.0.0
172.16.12.2, fib_nh:0,oce:0,status:0
Workaround:
Instead of apply set ip next-hop 172.16.12.2 in the route-map, apply:
set ip next-hop recursive 172.16.12.0 (network address) in the route-map
10 Replies 10
you haven't applied the route map too any interface as far as I can see ?
interface X
Did it on Fa4, where the ipsec traffic comes
Fa4 is the WAN interface. Your traffic is sourced locally. You need to apply the route map to a local interface (Vlan 2, where the source network is attached)...
Just for better understanding interesting traffic is 10.10.12.1 -> 172.16.59.22
Output L3 interface for it is Vlan532. with address 172.16.59.21
Tried to apply the route-map on it. No luck.
About the traffic source int - you can see in debug that it is Fa4.
For addition all my c7200 devices work with this config. There is something unknown for me only in this device.
I am not sure I understand fully what your network looks like, but 10.10.12.0 is an external network, that gets translated first and then policy routed (that is the NAT order of operation...
Can you draw out your network ?
Please look at the scheme
The task is to reach 172.16.59.22 from 10.10.12.1 translated to 172.16.59.21
CSCtw57637
Description
Symptom:
Conditions:
Match clauses:
Set clauses:
Workaround:
I don't understand why, but only subnet can be set as recursive hexthop.
Aaaand that worked like a charm!
 set ip next-hop recursive 1.1.1.0
*Sep 11 20:09:01.390: IP: s=10.10.12.1 (FastEthernet4), d=172.16.59.22, len 100, input feature, Common Flow Table(5), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
*Sep 11 20:09:01.390: IP: s=10.10.12.1 (FastEthernet4), d=172.16.59.22, len 100, input feature, Stateful Inspection(8), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
*Sep 11 20:09:01.390: IP: s=10.10.12.1 (FastEthernet4), d=172.16.59.22, len 100, input feature, Stateful Inspection On Cypher Text(9), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
*Sep 11 20:09:01.390: IP: s=10.10.12.1 (FastEthernet4), d=172.16.59.22, len 100, input feature, Virtual Fragment Reassembly(39), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
*Sep 11 20:09:01.390: IP: s=10.10.12.1 (FastEthernet4), d=172.16.59.22, len 100, input feature, Access List(47), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
*Sep 11 20:09:01.390: IP: s=10.10.12.1 (FastEthernet4), d=172.16.59.22, len 100, input feature, IPSec input classification(55), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
*Sep 11 20:09:01.390: IP: s=10.10.12.1 (FastEthernet4), d=172.16.59.22, len 100, input feature, Virtual Fragment Reassembly After IPSec Decryption(57), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
*Sep 11 20:09:01.390: IP: s=10.10.12.1 (FastEthernet4), d=172.16.59.22, len 100, input feature, uRPF(60), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
*Sep 11 20:09:01.390: IP: s=10.10.12.1 (FastEthernet4), d=172.16.59.22, len 100, input feature, Common Flow Table Post VPN(68), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
*Sep 11 20:09:01.390: IP: s=10.10.12.1 (FastEthernet4), d=172.16.59.22, len 100, input feature, Stateful Inspection On Clear Text(77), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
*Sep 11 20:09:01.390: IP: s=10.10.12.1 (FastEthernet4), d=172.16.59.22, len 100, input feature, NAT Outside(92), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
*Sep 11 20:09:01.394: IP: s=10.10.12.1 (FastEthernet4), d=172.16.59.22 (Loopback0), len 100, input feature, Policy Routing(103), rtype 2, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
*Sep 11 20:09:01.394: IP: s=10.10.12.1 (FastEthernet4), d=172.16.59.22 (Loopback0), len 100, input feature, MCI Check(109), rtype 2, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
*Sep 11 20:09:01.394: IP: s=10.10.12.1 (FastEthernet4), d=172.16.59.22 (Loopback0), len 100, output feature, NAT Inside(8), rtype 2, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
*Sep 11 20:09:01.394: IP: s=10.10.12.1 (FastEthernet4), d=172.16.59.22 (Loopback0), len 100, output feature, Common Flow Table(29), rtype 2, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
*Sep 11 20:09:01.394: IP: s=10.10.12.1 (FastEthernet4), d=172.16.59.22 (Loopback0), len 100, output feature, Stateful Inspection(30), rtype 2, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
*Sep 11 20:09:01.394: IP: s=10.10.12.1 (FastEthernet4), d=172.16.59.22 (Loopback0), len 100, output feature, Firewall (NAT)(50), rtype 2, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
*Sep 11 20:09:01.394: IP: s=10.10.12.1 (FastEthernet4), d=172.16.59.22 (Loopback0), len 100, output feature, Firewall (inspect)(56), rtype 2, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
*Sep 11 20:09:01.394: IP: s=10.10.12.1 (FastEthernet4), d=172.16.59.22 (Loopback0), len 100, output feature, NAT ALG proxy(63), rtype 2, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
*Sep 11 20:09:01.394: IP: s=10.10.12.1 (FastEthernet4), d=172.16.59.22 (Loopback0), g=1.1.1.0, len 100, forward
*Sep 11 20:09:01.394: IP: s=10.10.12.1 (FastEthernet4), d=172.16.59.22 (Loopback0), len 100, sending full packet
*Sep 11 20:09:01.394: IP: s=10.10.12.1 (Loopback0), d=172.16.59.22, len 100, input feature, Common Flow Table(5), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
*Sep 11 20:09:01.394: IP: s=10.10.12.1 (Loopback0), d=172.16.59.22, len 100, input feature, Stateful Inspection(8), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
*Sep 11 20:09:01.394: IP: s=10.10.12.1 (Loopback0), d=172.16.59.22, len 100, input feature, Virtual Fragment Reassembly(39), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
*Sep 11 20:09:01.394: IP: s=10.10.12.1 (Loopback0), d=172.16.59.22, len 100, input feature, Virtual Fragment Reassembly After IPSec Decryption(57), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
*Sep 11 20:09:01.394: IP: s=10.10.12.1 (Loopback0), d=172.16.59.22, len 100, input feature, MCI Check(109), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
*Sep 11 20:09:01.394: IP: s=172.16.59.21 (Loopback0), d=172.16.59.22 (Vlan532), len 100, output feature, Post-routing NAT Outside(26), rtype 1, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
*Sep 11 20:09:01.394: IP: s=172.16.59.21 (Loopback0), d=172.16.59.22 (Vlan532), len 100, output feature, Common Flow Table(29), rtype 1, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
*Sep 11 20:09:01.394: IP: s=172.16.59.21 (Loopback0), d=172.16.59.22 (Vlan532), len 100, output feature, Stateful Inspection(30), rtype 1, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
*Sep 11 20:09:01.394: IP: s=172.16.59.21 (Loopback0), d=172.16.59.22 (Vlan532), len 100, output feature, Firewall (NAT)(50), rtype 1, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
*Sep 11 20:09:01.394: IP: s=172.16.59.21 (Loopback0), d=172.16.59.22 (Vlan532), len 100, output feature, Firewall (inspect)(56), rtype 1, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
*Sep 11 20:09:01.394: IP: s=172.16.59.21 (Loopback0), d=172.16.59.22 (Vlan532), len 100, output feature, NAT ALG proxy(63), rtype 1, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
*Sep 11 20:09:01.394: IP: s=172.16.59.21 (Loopback0), d=172.16.59.22 (Vlan532), g=172.16.59.22, len 100, forward
*Sep 11 20:09:01.394: IP: s=172.16.59.21 (Loopback0), d=172.16.59.22 (Vlan532), len 100, sending full packet
Georg, thanks a lot for solution!
you were right, it was platform (800) specific. Not sure why the subnet is required, I guess that's why they call it a bug...I tested your config in GNS3 and it works just fine.
Either way, glad that you got it resolved !
Kind Regards
Paul
