05-09-2022 09:57 AM
I have a question about the Cisco C886VAG-LTE-GA-K9, in my logfile you can see the following from time to time
May 9 18:32:32.743 CEST: %SCHED-3-THRASHING: Process thrashing on watched message queue 'dummy watched message'. -Process= "SSH Process", ipl= 6, pid= 467 -Traceback= 71AFD80z 404DFB4z 5D75460z 5D657A4z 5D0F498z 5D1E718z 70FC7A0z 70FDAA0z 710EF5Cz A71EA84z A710FF8z 60BEEACz 60A5DCCz May 9 18:33:35.768 CEST: %SCHED-3-THRASHING: Process thrashing on watched message queue 'dummy watched message'. -Process= "SSH Process", ipl= 6, pid= 361 -Traceback= 71AFD80z 404DFB4z 5D75460z 5D657A4z 5D0F498z 5D1E718z 70FC7A0z 70FDAA0z 710EF5Cz A71EA84z A710FF8z 60BEEACz 60A5DCCz May 9 18:34:38.917 CEST: %SCHED-3-THRASHING: Process thrashing on watched message queue 'dummy watched message'. -Process= "SSH Process", ipl= 6, pid= 174 -Traceback= 71AFD80z 404DFB4z 5D75460z 5D657A4z 5D0F498z 5D1E718z 70FC7A0z 70FDAA0z 710EF5Cz A71EA84z A710FF8z 60BEEACz 60A5DCCz
These messages are only displayed to me, I also have a problem with my backup, the interface Tunnel 0 then goes up/down, only a reload usually helps here. But it can't be the solution to the problem.
05-10-2022 12:14 AM
- Check current software version , use advisory release if applicable :
https://software.cisco.com/download/home/284003447/type/280805680/release/15.7.3M4a
M.
05-10-2022 05:49 AM
Hallo Marce1000,
I checked the software, I have IOS c800-universalk9-mz.SPA.158-3.M5.bin this is currently installed on the router
Andreas
05-10-2022 07:00 AM
try and use the exec command:
clear tcp tcb
There is a bug, but it (in theory) applies only to the 12.2S train.
I found the additional explanation below:
These thrashing checks are intended to determine if a process is, for some
reason, not doing its job. The thrashing check on watched queues (which is
the troublesome message which is signaling) checks the number of elements
on the queue. If this number remains the same for a given number of
schedulings, the message is printed.
Unfortunately, some queues are length-limited, meaning that if the router
gets very busy, the queues always stay at the maximum. As a result, the
thrashing code in the scheduler gets confused and thinks that these queues
have not been handled. The thrashing code has determined that the process
which was supposed to handle the queue was not doing its job and prints
the thrashing message.
The scheduler has been changed in later Cisco IOS software code. To keep
track of whether the queues have been changed (so it can better determine
whether or not the process is thrashing), the scheduler now notes whenever
an item is removed from the queue, and only prints the thrashing message
if nothing gets removed for a while.
Most of the time, the queue thrashing message is simply cosmetic.
These messages are not always caused by a software bug. They may be issued
in response to either instantaneous or sustained demand on the router.
Increased or persistent messages may indicate that the traffic load needs
to be reviewed.
05-10-2022 07:43 AM
Hy Georg,
thanks for the information I will test this and if this is ok I would report back if it worked or not
THX
Andreas
