C891 router: IP addresses may not be configured on L2 links
leninpandian
would like to assign an IP address to fa interface
am using C890 router and encountering " IP addresses may not be configured on L2 links". Apparently all fa1-7 ports under Default Vlan1...
Spoiler
Tried conf t
Int fa0
No switch-port access/ no switch-port access vlan 1/ etc...
Still in-vain..Please help
2 Accepted Solutions
luis_cordova
Hi @leninpandian ,
A: That's right.
The addressing for those ports must be done in the interface vlan1
Check this guide:
https://www.cisco.com/c/en/us/td/docs/routers/access/800/software/configuration/guide/SCG800Guide/SCG800_Guide_BookMap_chapter_010.html#con_1220740
Configuring the Fast Ethernet LAN Interfaces
The Fast Ethernet LAN interfaces on your router are automatically configured as part of the default VLAN and are not configured with individual addresses. Access is provided through the VLAN.
Router_Primary#SH RUN ALL | i 192.168.1.1
standby 0 ip 192.168.1.1
What interface is this configured under ? Try and default the interface in question:
C891#conf t
C891(config)#default interface x
luis_cordova
Hi @leninpandian ,
A: That's right.
Check this guide:
Thanks for the reply. Can you please help input on how to remove the standby 0 ip ,pls
tried "no ip address standby 0" in vain
C891#conf t
