%CABLE_MODEM_HWIC-3-CONTROL_PLANE_FAIL: RBCP failure : Adding service flow ACE failed - Ethernet type not supported
DialerString_2
Level 3
Level 3
Hello all...
I'm getting %CABLE_MODEM_HWIC-3-CONTROL_PLANE_FAIL: RBCP failure : Adding service flow ACE failed - Ethernet type not supported
on my 1841 which is currently setup for L2L via cable internet. Has anyone seen this before? I can't seem to find anything on Cisco related to this.
The tunnel comes up and I had the same configs using DSL except the interfaces are different. THANKS...
My configs are below:
crypto isakmp policy 10
encr 3des
hash md5
authentication pre-share
group 2
crypto isakmp key #### address a.a.a.a
crypto isakmp keepalive 20 periodic
crypto ipsec security-association lifetime seconds 28800
crypto ipsec transform-set xform esp-3des esp-md5-hmac
crypto ipsec df-bit clear
crypto map VPN 10 ipsec-isakmp
set peer a.a.a.a
set transform-set xform
set pfs group2
match address CRYPTO_ACL
interface Cable-Modem0/1/0
no ip address
bridge-group 1
bridge-group 1 spanning-disabled
interface BVI1
ip address 98.x.x.x 255.255.255.224
ip virtual-reassembly
crypto map VPN
Hello DialerString,
I'm afraid that the ACL is not related to the issue so I would not expect to see anything in debug output
Hope to help
Giuseppe
6 Replies 6
Giuseppe Larosa
the message:
says that cable modem HWIC had a problem at layer 3, an ACL line also named ACE is not compatible with HWIC, the ACL line may be trying to match on ethertype (protocol over ethernet)
How is configured the ACL used in the crpyto map?
Hope to help
Giuseppe
Well the crypto acl is below and I don't have anything on my router that has "ACE". Do you think it could be a broadcast coming of that links since it's configure for bridging?
ip access-list extended CRYPTO_ACL 10.1.17 is my lan
remark Encrypted Traffic
permit ip 10.1.17.0 0.0.0.255 10.0.0.0 0.255.255.255
permit ip 10.1.17.0 0.0.0.255 any
This acl is applied to the BVI1 interface which is bridged to the c0/1/0
ip access-list extended INET_ACL 38.x.x.x is my firewall that terminates the vpn.
remark Internet Traffic
permit udp host 38.x.x.x any eq isakmp
permit esp host 38.x.x.x any
permit tcp host 38.x.x.x any eq 22
Hello DialerString,
ACE stays for ACL control element and is the equivalent of ACL line/statement
I agree that your ACLs are  IP ACLs so the message looks like somewhat not related to your current setup.
Also you are using IRB so it is possible that layer 2 frames like broadcast try  to go between physical interfaces.
There is an impact on service or your connectivity is fine?
hope to help
Giuseppe
Thanks for the reply Guislar. Yes, it does impact service but for a brief moment 10-30 seconds are so but the tunnels don't drop. I guess I can debug the ACL on that interface, bring the int down and back up. Hopefully I can reproduce the error on the fly. What do you think, Guislar?
Hello DialerString,
Hope to help
Giuseppe
Figured out what he problem was and come to find out there's an issue the providers CMTS that causing the link to go down for 7 seconds and back up again. Thanks Guislar!
