Caller ID validation using a cisco 3725
brad.hodges
I am relativly new ISDN and i was wondering how i would go about doing some sort of CLI verification on a number that has dialed into the router via an isdn pri line.
Regards Brad
Hello Brad,
what is your current logging level ?
use sh logging to see your current setup.
sh isdn history could be helpful too
Hope to help
Giuseppe
5 Replies 5
Giuseppe Larosa
Hello Brad,
the isdn caller command given int interface serx/y:15 (E1 channel D) or serx/y:23 (T1 channel D) could be useful.
If using DDR the command can be given under interface dialer.
Hope to help
Giuseppe
Giuseppe
Thanks for your feedback, i will give it a go.
Regards Brad
Solution works brilliantly, however is there some way to log reject calls? as i cant see them in the log file.
Hello Brad,
Hope to help
Giuseppe
Giuseppe
Thanks for your reply. i very much appreciate your help. My logging is currently set to informational which i will adjust to suite our needs.
Regards Brad
