Can 877 set bridge mode
thanaponsom
I have some scenario to provide network for my cutomer
I have 2 Cisco 877 routers and I need one set to bridge mode and one is gateway internet
How do I do?
                                          (LAN)
ADSL <---------------->877 <----------------> 877 Gateway <-----------> Clients
There are a number of examples for how to configure bridge mode on 800 series access routers here: http://www.cisco.com/en/US/products/hw/routers/ps380/prod_configuration_examples_list.html
Maybe some config like this:
no ip routing
interface FastEthernet0
switchport access vlan 1
interface Vlan1
bridge-group 1
interface ATM0
no ip address
no atm ilmi-keepalive
interface ATM0.1 point-to-point
description connection to service provider
pvc 0/33
encapsulation aal5mux
bridge-group 1
bridge 1 protocol ieee
You'll need to change the specific numbers, like PVC numbers, to be correct for your ISP connection.
Using a Cisco router as a bridge is kind of silly though since it turns it into a passive modem device mostly. You could use any modem your ISP might provide for that and have the same result.
Thank you Jonathan
Because I set this topology to test Cisco 877 to run on PPPoE
I have only 2 Cisco 877 to test
1 thing how should I know which I'll use encapsulation
Generally your ISP will determine that.
