Can anyone explain(thro why am able to ping end to end with 1500 data size
sanjoy2006
According the diagram 802.q will make another 4 byte overhead so it will 1522
switch also 1500 system mtu so it will forward 1518(frame overhead 18 byte )
6 Replies 6
Giuseppe Larosa
Hello Sanjoy,
1522 bytes 802.1Q tagged frames are baby giants and the switch may be able to handle them without changing the system mtu.
For this reason you are still able to ping with 1500 byte IP packet size even if you use an 802.1Q trunk.
Hope to help
Giuseppe
2950 support 1522 frame size , I have very much doubt .
1518 it support frame header 14 plus 4 byte header
Hello Sanjoy,
see it as feature that allows you to send IPv4 packets with size 1500 bytes over a trunk without need to explicitly change the system MTU.
I used C2950 and we tested it.
We did MTU tests for MPLS VPN with the C2950 on the access link side.
by the way it is:
1500 byte IP
14 byte ethernet header
4 byte FCS
4 byte 802.1Q tag
1522
I agree this switch doesn't support system mtu command but trunking has to be transparent to end users so baby giants are supported
see
http://www.cisco.com/en/US/docs/switches/lan/catalyst2950/software/release/12.1_22_ea11x/command/reference/bootldr.html
about trunks
http://www.cisco.com/en/US/docs/switches/lan/catalyst2950/software/release/12.1_22_ea11x/configuration/guide/swvlan.html#wp1200245
you cannot use it on a MPLS network but as access switch it can do its job on any combination of access ports and 802.1Q trunks.
Hope to help
Giuseppe
Sanjoy
I believe that the explanation is that when they build the switch interface logic to support dot1x trunking, that they build in support to recognize and process the tagging, including the extra 4 bytes, without considering it a violation of the system MTU. This is very similar to the way that they support the Ethernet header and the FCS which make a frame actually 1518 without violating the System MTU of 1500.
Rick
Rick
right this is the exact RCA I have also find same document .
Thanks rburt.
As a workaround, you can enable a port for trunking in order to support baby giants. When you enable a port for 802.1q trunking, the switch automatically assumes that an extra four bytes of data are appended on, and increment the frame size of the L2 packet. Note that ISL encapsulation is not supported on these platforms.Hence, for implementations that require exactly one tag to be carried (either 802.1q or MPLS, but not both), you can configure the port as a trunk port to force the switchport to accept an extra four bytes of data. If the port were to carry multiple VLANs for VLAN-ID tagging or 802.1p prioritization, configure the port as a 802.1q trunk. However, even if VLAN tagging is not necessary, but you want the increased four-byte support, you can configure the port as a 802.1q trunk. Change the Native VLAN to be the one desired to carry
the traffic. When you do so, you can accommodate an extra four bytes of data
Now take a look
2960-24TT-L
interface GigabitEthernet0/1
switchport trunk allowed vlan 1,13,20,23,69
switchport mode trunk not support baby giant support only 1518
load-interval 30
end
3560G
switchport trunk encapsulation dot1q So support baby giant 1522
switchport trunk allowed vlan 1,50
load-interval 30
storm-control multicast level bps 500m
spanning-tree portfast
spanning-tree bpdufilter enable
spanning-tree guard root
end
3750G
interface GigabitEthernet1/0/28
switchport trunk encapsulation dot1q it will support 1522 baby giant
switchport trunk allowed vlan 10,51
speed nonegotiate
end
