Can Cisco3945E support VRF-Lite ?
Takuro Moriyama
Dear Expert,
Hello.
May I ask you a question ?
Can Cisco 3945E support VRF-Lite ?
regards,
takuro
5 Replies 5
Leo Laohoo
If you enable Enterprise license, this license should enable MPLS/VRF/VRF-Lite.
Dear leolaohoo,
Hello. Thank you for you advise.
It is case of IOS 12.x,isn't it?
My case is IOS 15.x.
In that case, Can I enable VRF-Lite feature by DATA license ?
regards,
takuro
Whether you are running 12.X or 15.X doesn't make a difference.
Post the output to the command "sh license".
Dear leolaohoo,
My explanation was not enough, I'm afraid.
I'm going to buy the Cisco 3945E.
Requirement are below:
  - Need to run VRF-Lite
  - IOS is 15.4
    the rest details are omitted.
Based on your advice, I checked a VRF-Lite at CCO.
To run VRF-Lite, It is needed a DATA license.
Is it correct ?
Please advice to me when my idea is wrong.
regards,
takuro
andrekeuler
As per the following article (right at the bottom), you only need IP Base for Multi-VRF support.
http://www.cisco.com/en/US/prod/collateral/iosswrel/ps6537/ps6557/prod_white_paper0900aecd8051fbdc.html
Extract from article:
Table 3. Minimum Required Cisco IOS Feature Set
Platform
Multi-VRF
MPLS Label Switching
Cisco 3900 Series
IP Base
Data license
