Can dedicated & dynamic QoS co-exist?
mgeo
Hi everyone.
I have 2 sites (central & remote) with a PBX on each site. Both PBXs are connected via ethernet to the LANs. I have configured dynamic QoS for the IP addresses of the PBXs on each site. The problem is that dynamic bandwidth needs 5 minutes to "give" the configured bandwidth. This means that my voice calls face some (voice) interruptions when the call is established. After a while (when the configured bandwidth is given by the QoS policy) the voice is great.
I was wondering if I can give some dedicated bandwidth for the PBXs (i.e. 50Kbps) and if they need more bandwidth, they could "ask" for more (i.e. 200Kbps).
Can someone help me on this?
Thank you.
shailesh.h
Can you share the current setup to suggest some either improvement or new configuration to apply?
CENTRAL SITE
class-map match-all VoiceBW_cmap
match access-group name VoiceBW_list
policy-map VoiceBW_pmap
class VoiceBW_cmap
  bandwidth 512
class class-default
  fair-queue
interface serial0/0/0:0
description #### link to remote side ####
service-policy output VoiceBW_pmap
ip access-list extended VoiceBW_list
permit ip any host 192.168.0.90
permit ip host 192.168.0.90 any
REMOTE SITE
class VoiceBW_cmap
  bandwidth 512
class class-default
  fair-queue
interface serial0/0/0:1
description #### link to central site ####
permit ip any host 192.168.1.90
permit ip host 192.168.1.90 any
If you change the voice class to use the 'low latency queue' by using the priority command quality should improve.
class VoiceBW_cmap
  priority 512
class class-default
  fair-queue
Chris
