12-06-2011 08:31 PM - edited 03-04-2019 02:32 PM
the distance between two location is 70 KM, i don't know the latency between two location.
is there any requirement for this Scenario
thank you!
12-13-2011 05:07 PM
is there any one has experience implementing VSS in different location?
12-13-2011 05:48 PM
There is no limitation on how far the devices can be. The limitation is your single mode fiber optic distance limitation not the VSS. So, the longest an X2 module (X2-10GB-ER) can reach safely is 30KM.
have a look at this doc:
12-13-2011 06:10 PM
I know this method, But i am really worry about this implement method. because i haven't seen real implementation. if we meet problem after build vss like this, it is very difficult to troubleshooting and repair.
i know juniper cluster need latency time bellow 100ms, does vss has same requirement?
thank you!
