Can i know how to configure this??
azlinazri93
the last is computer in ipv4 can ping the ipv6 computer...
i want trying to use RIP route...
can i get the command and some explanation??
Here are some nice tutorials (slides+videos) explaining all details which you need for start...maybe even more.
cisco learning network
Introducing IPv6
http://www.cisco.com/web/learning/le31/le46/cln/qlm/CCNP/bsci/Introducing-IPv6-BSCI/player.html
Using IPv6 with OSPF and Other Routing Protocols
http://www.cisco.com/E-Learning/bulk/public/ccnp/QLM_Using_IPv6_with_OSPF_and_Other_Routing_Protocols/player.html
Implementing IPv6 : Using IPv6 with IPv4
http://tools.cisco.com/cmne/jsp/index.jsp?id=90470&redir=YES
CBT videos with Jeremy,at the bottom of page you can select parts 25-28 which are dealing with IPv6
http://www.cbtnuggets.com/it-training-videos/series/cisco-ccnp-route-642-902/7442
helpful slides + labs
http://www.slideshare.net/kriz5/cisco-i-pv6labandtechtorialworkshop-v0
and many more on google....
I think that if you watch all CBT videos, you will be able to built some simple IPv6 topology on your own.
If you need any help, let us know...
Best Regards
Please rate helpful posts
Best Regards Please rate all helpful posts and close solved questions
blau grana
Level 7
Level 7
One host is IPv4 host and other is IPv6 host according  your topology. If you do not use some tool which allow communication  between two different protocols, they can not communicate with each  other.
And I do not think that you can do something like that in cisco packet tracer.
http://www.cisco.com/en/US/prod/collateral/iosswrel/ps6537/ps6553/white_paper_c11-676278.html
http://en.wikipedia.org/wiki/IPv6_transition_mechanisms
http://ntrg.cs.tcd.ie/undergrad/4ba2.02/ipv6/interop.html
Best Regards
hi...thnx for advice...
i'm just a newbie about networking...i'm a student and need to make a small network using ipv6...
but i didn't understand the concept...
my instructor said try to explore using RIP...
can u explain me how to make a small network using ipv6??
Introducing IPv6
Best Regards
thanks dude...really helpful..
i'm going to start learning all that you give...
Nice 1!
