09-24-2018 10:03 AM - edited 03-05-2019 10:56 AM
I have a 2911 Router that I'm looking to swap with a 2951 Router.
They have different cards and modules.
Is it possible to switch them and still support the same config? I also attached configs.
If they can be swapped how can I match up the interfaces.
Here is the inventory of both routers.
OLD
tke-rtr1#show inv NAME: "CISCO2911/K9", DESCR: "CISCO2911/K9 chassis, Hw Serial#: FTX1822AJBF, Hw Revision: 1.0" PID: CISCO2911/K9 , VID: V07 , SN: FTX####### NAME: "VWIC3-1MFT-T1/E1 - 1-Port RJ-48 Multiflex Trunk - T1/E1 on Slot 0 SubSlot 0", DESCR: "VWIC3-1MFT-T1/E1 - 1-Port RJ-48 Multiflex Trunk - T1/E1" PID: VWIC3-1MFT-T1/E1 , VID: V01 , SN: FOC###### NAME: "2nd generation four port FXO voice interface daughtercard on Slot 0 SubSlot 2", DESCR: "2nd generation four port FXO voice interface daughtercard" PID: VIC2-4FXO , VID: V04 , SN: FOC182871KB NAME: "3rd generation four port FXS DID voice interface daughtercard on Slot 0 SubSlot 3", DESCR: "3rd generation four port FXS DID voice interface daughtercard" PID: VIC3-4FXS/DID , VID: V02 , SN: FOC####### NAME: "PVDM3 DSP DIMM with 16 Channels on Slot 0 SubSlot 4", DESCR: "PVDM3 DSP DIMM with 16 Channels" PID: PVDM3-16 , VID: V01 , SN: FOC##### NAME: "PVDM3 DSP DIMM with 16 Channels on Slot 0 SubSlot 5", DESCR: "PVDM3 DSP DIMM with 16 Channels" PID: PVDM3-16 , VID: V01 , SN: FOC###### NAME: "C2911 AC Power Supply", DESCR: "C2911 AC Power Supply" PID: PWR-2911-AC , VID: V05 , SN: DCA########
NEW
NAME: "CISCO2951/K9", DESCR: "CISCO2951/K9 chassis, Hw Serial#: FGL155012GA, Hw Revision: 1.1" PID: CISCO2951/K9 , VID: V05 , SN: FGL######## NAME: "VWIC3-4MFT-T1/E1 - 4-Port RJ-48 Multiflex Trunk - T1/E1 on Slot 0 SubSlot 0", DESCR: "VWIC3-4MFT-T1/E1 - 4-Port RJ-48 Multiflex Trunk - T1/E1" PID: VWIC3-4MFT-T1/E1 , VID: V01 , SN: FOC###### NAME: "3rd generation four port FXS DID voice interface daughtercard on Slot 0 SubSlot 1", DESCR: "3rd generation four port FXS DID voice interface daughtercard" PID: VIC3-4FXS/DID , VID: V02 , SN: FOC14392RDG NAME: "PVDM3 DSP DIMM with 32 Channels on Slot 0 SubSlot 4", DESCR: "PVDM3 DSP DIMM with 32 Channels" PID: PVDM3-32 , VID: V01 , SN: FOC####### NAME: "C2921/C2951 AC Power Supply", DESCR: "C2921/C2951 AC Power Supply" PID: PWR-2921-51-AC , VID: V03 , SN: DCA#######
09-24-2018 11:16 AM
From what I can see, everything should be compatible.
The only component I didn't see for the 2900 was the VWIC3-4MFT-T1/E1, but then it shouldn't work in the 2901, but that's not the case, and this link says it should:
Hope this helps
09-24-2018 03:05 PM
Should be fine.
