can i use CISCO 1841 router as a FTP or server
sujitkr7cisco
I want to save mac-binding file (.txt)in flash so that router DHCP server use this file to authonicate user.
Leo Laohoo
Yes, if your compact flash is big enough.
Why do you want to do this and why not storing this information on the DHCP server itself?
I want to save my mac binding file in Flash or NVRAM and then my origin paath is just same (NVRAM or Flash).
I wouldn't suggest saving anything on the NVRAM (because there's a fixed amount of disk space) and Compact Flash (because you want to use this to save your IOS(es).
Again, I would like to ask why not consider saving the files on your DHCP server instead?
Right now i am using same router as a DHCP server.So i am saveing mac binding with ip address and want to save in FLASH and using this file through as origin . and every time user ip is authenticated by mac address which is binded in .TXT file.
