Can IPSLA tack 3 interface?
Requiem11141
I want to know how to track if you have 3 internet interface.
If Primary internet interface down or lost ping, then will go to secondary internet interface.
If both Primary and Secondary go down, then go to third one.
Does anyone how to configure that?
Thanks in advance.
11 Replies 11
Samer R. Saleem
Level 4
Level 4
what is your current routing methid? is it BGP or Static?
as a suggestion, why not using BFD?
Use static route for all internet interface, and can't do BFD with SP.
ok, find my reply and let me know if its helpful, good luck!
Samer R. Saleem
Level 4
Level 4
in case you are using static routing,
R1 is your local router, which 2,3,4 are ISP routers, you will use default route to each router with different administrative distance and track it by and the track is associated with SLA that pings the interface of ISP routers
12.0.0.2 and 13.0.0.3 and 14.0.0.4, you can try the configs in a lab first
find the config attached
I think you need only two IP SLAs. In addition, I would include two EEM scripts to clear the NAT tables in case of failover. So the whole thing would look like below (IP addresses and interfaces are arbitrary, obviously). If you have trouble getting this configured, post the configuration of your router and indicate which interfaces are primary, secondary, and backup.
track 1 ip sla 1
track 2 ip sla 2
ip route 0.0.0.0 0.0.0.0 192.168.12.2 track 1
ip route 0.0.0.0 0.0.0.0 192.168.13.2 10 track 2
ip route 0.0.0.0 0.0.0.0 192.168.14.2 20
ip sla 1
icmp-echo 8.8.8.8 source-interface GigabitEthernet0/1
frequency 5
ip sla schedule 1 life forever start-time now
ip sla 2
icmp-echo 8.8.8.8 source-interface GigabitEthernet0/2
frequency 5
ip sla schedule 2 life forever start-time now
event manager applet CLEAR_NAT
event track 1 state any
action 1.0 cli command “enable”
action 2.0 cli command “clear ip nat translation *”
event track 2 state any
this is one nice method, nice work with EEM
very nice solution
Is there a good guide for learning EEM basics? thanks
the link below is a good start:
Embedded Event Manager Configuration Guide
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/eem/configuration/xe-16/eem-xe-16-book.html
thanks Georg
wrong post - apologies
Kind Regards
Paul
