can not browse internet
malai.joseph
Hi can not browse internet but am able to ping from vlan 3 to vlan 4 and vice versa
vlan 4 is users,vlan 3 is a server farm and has proxy squid 192.168.3.6 all suppose to pass here and set with some rules (this is perfect no problem if has no vlan on it users can broswe and when router has no acess list 100 and 102 )
Now i need to employ access list on router, acess list 100 and 102but users can not browse and ping from router to wan does not recognize
pls help on router and switches see attached
30 Replies 30
Malai,
perfect for what? You wanted to know how to get the router acting like a firewall. Putting the access-lists on is the first place I'd start. After you reapply the access list you'll have to figure out what if anything you broke, and then if this is line with whatever policy you happen to be setting this up for.
the earlier advice you received to remove the access-lists was in aid of getting it up and working. Once everything seems to be good, you can reinstall the access-lists knowing that it used to work and that the last change broke it the way you expected or did something you weren't expecting.
It's a good idea to figure out what your policies are, and  then figure out what systems you need to enforce this.
Tony
