Can not connect with FTP server using NAT.
conectividade
Hi, folks!
One machine (ftp client) in the net 200.2.2.0, with ip 200.2.2.222 needs to connect
with a FTP server out there, using the ip nat 201.1.1.222, but, that can not connect.
Using an acl in log, in interface serial I saw the server answering to request of connect.
Using another acl out log, in interface fas0/1 I can not see the answer of server, I can
not see if nat was did.
why?
What's wrong?
What can I do?
To put this machine in another net, 201.1.1.0 is so difficult!
Look, one interface of router has ip 201.1.1.1.
interface FastEthernet0/0
ip address 201.1.1.1 255.255.255.0
no cdp enable
interface FastEthernet0/1
ip address 200.2.2.2 255.255.255.0
ip nat inside
no cdp enable
interface Serial0/0
description INTERNET
ip address 100.100.100.30 255.255.255.252
ip nat outside
no cdp enable
ip nat inside source static 200.2.2.222 201.1.1.222
no ip http server
thanks in advance,
Renato
Hello Renato,
also it shouldn't make a difference, since your access list allows everything with the last statement, try and add the following to your access list:
access-list 103 permit tcp any any established
access-list 103 permit tcp any eq ftp host 201.1.1.222 log
--> access-list 103 permit tcp any eq ftp-data host 201.1.1.222 log
access-list 103 permit tcp any eq ftp host 200.2.2.222 log
--> access-list 103 permit tcp any eq ftp-data host 200.2.2.222 log
access-list 103 permit tcp any any range 0 65365 log
access-list 103 permit udp any any range 0 65365
access-list 103 permit icmp any any log
access-list 103 permit ip any any log
Also, try to remove the access list alltogether and see if that makes a difference...
GP
8 Replies 8
Hello Renato,
try and add the following to your configuration:
ip nat inside source static tcp 200.2.2.222 20 201.1.1.222 20 extendable
ip nat inside source static tcp 200.2.2.222 21 201.1.1.222 21 extendable
This is for both ports FTP uses (20 and 21).
GP
GP,
It does not work, do you known what version of IOS
has this new function?
The version of our router is C2691-JS-M Version 12.3(9a).
2691(config)#ip nat inside source static 200.2.2.222 20 201.1.1.222 20 extendable
% Invalid input detected at '^' marker.
thanks,
Renato
Hello Renato,
I think you got the syntax wrong:
I think you forgot to specify the protocol, tcp in this case...
GP
Hi GP,
I did that cfg, look below:
ip nat inside source static tcp 200.2.2.222 20 201.1.1.22 20 extendable
ip nat inside source static tcp 200.2.2.222 21 201.1.1.22 21 extendable
And this did not work.
I saw the answer of ftp server in interface serial:
%SEC-6-IPACCESSLOGP: list 103 permitted tcp 192.18.108.40(21) -> 201.1.1.222(37781), 1 packet.
But I did not see this in interfaces fas.
Any other idea to help us?
thanks,
Renato
what does your access list 103 look like ? Can you post the configuration of the router where access list 103 is configured ?
GP
GP,
I only use this to watch, look acl 103:
interface Serial0/0
ip access-group 103 in
ip nat outside
no cdp enable
I started a debug ip nat, that show me:
Mar 17 11:44:19.882: NAT: s=192.18.108.40, d=201.1.1.222->200.2.2.222 [29486]
Mar 17 11:44:20.066: NAT: s=192.18.108.40, d=201.1.1.222->200.2.2.222 [29487]
Mar 17 11:44:20.854: NAT: s=192.18.108.40, d=201.1.1.222->200.2.2.222 [29488]
Mar 17 11:44:21.050: NAT: s=192.18.108.40, d=201.1.1.222->200.2.2.222 [29489]
thanks,
Renato
Hello Renato,
GP
Hello GP,
when I tried to connect with 192.18.108.40, I received msg: connection closed by remote host.
I did connect with anothers FTP servers and I received a prompt of user (ftp.iof.mg.gov.br and ftp.rfc-editor.org). So I connected, not logged, but connected.
What can I do to connect with FTP server 192.18.108.40?
thanks,
Renato
