can not static nat (port forwarding) port 554 on isr4300 router
n.bokhar1
hi guys
i have an isr 4331 router and i want to do static nat or port forwarding on this router but when i use this command:
ip nat inside source static tcp 10.10.10.1 554 interface gig 0/0/1 554
i get a err which says the port 554 is being used by the system how can i forbid system of using port 554
and i can do my nat
Hi @n.bokhar1
Port 554 is used by RTSP protocol. But, which is your idea by doing this PAT?
-If I helped you somehow, please, rate it as useful.-
i have pat but i have a server in my network which need s to work with port 554 and i want to do a port forwarding on that port
Hello
Try a port-map statement?
access-list 1 permit host 10.10.10.1
ip port-map rtsp port 554 list 1
res
Paul
Kind Regards
Paul
