Can Ping Internet From Router, but not From Host?
JovanGeary94
I'm trying to set up a separate network for my home lab.
My internet comes in from my Netgear Router on 192.168.0.1
I've set up my 2811 with FA0/1: 192.168.0.2, FA0/0 198.168.0.1
Host device is 198.168.0.10
Configured RIP(v2) between 192.168.0.0 and 198.168.0.0
Configured default route on the 2811: 0.0.0.0 0.0.0.0 192.168.0.1
I can ping the internet from the router itself, but I cannot ping from my host on the 198.168.0.0 network.
I've also configured two ACLs to permit traffic from both the 192 and 198 networks.
I'm not sure why I can't get the host to reach outside to the internet, any suggestions. Thank you. Below is the router config:
Current configuration : 1212 bytes
! Last configuration change at 05:58:21 UTC Mon Mar 16 2020
version 15.1
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
dot11 syslog
ip source-route
ip cef
no ipv6 cef
voice-card 0
license udi pid CISCO2811 sn FTX1113A24R
redundancy
interface FastEthernet0/0
ip address 198.168.0.1 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/1
ip address 192.168.0.2 255.255.255.0
duplex auto
speed auto
interface Serial0/0/0
no ip address
shutdown
router rip
version 2
network 192.168.0.0
network 198.168.0.0
default-information originate
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 192.168.0.1
access-list 1 permit 192.168.0.0 0.0.0.255
access-list 1 permit 198.168.0.0 0.0.0.255
control-plane
mgcp profile default
line con 0
line aux 0
line vty 0 4
login
transport input all
scheduler allocate 20000 1000
end
5 Replies 5
duplex auto
speed auto
duplex auto
speed auto
Both interfaces have an IP address from the same address space. You need to use a different IP subnet on FastEthernet0/1 (which I assume is the LAN interface), and then either configure the Netgear router to route and NAT this new network, or use double NAT on your 2901. What model is the Netgear ?
Hello
The reason being is the negear router is performing network translation for 192.168.1.0/24 however it isnt for the 192.168.2.0/24, so you need either to configure the netgear router to nat for the 192.168.2.0/24 of do this on your attached router
on the router:
int fa0/1
ip nat inside
int fa0/0
ip nat outside
access-list 10 permit 192.168.2.0 0.0.0.255
ip nat inside source list 10 interface fa0/0
Kind Regards
Paul
Thanks for the reply.
FA0/1 is actually WAN facing, however from what you've posted it doesn't sound like I can get the host to reach the internet via RIP and a default route, I'd have to set up NAT. I've actually already done this however I was hoping I could configure internet access to the host through RIP so I wouldn't have to VPN/TeamViewer to the host for management. Thank you.
you can use RIP or statc routes or whatever you want, as long as the networks can reach the Netgear. On the Netgear, you have to configure NAT for the additional network configured on the Cisco, and a route to that network. Or, as stated, NAT the new Cisco network to the IP address that is part of the Netgear LAN subnet...
Does that make sense ?
There are things that we do not know about the environment of the original poster. But if the environment really is one subnet (one interface) for local connection and one subnet (one interface) for a transit connection to the Internet provider then there is not any need for a routing protocol like RIP. All that is required is a static default route pointing to the Internet provider. And unless the original poster has a registered Public IP subnet for their Lan then address translation is required. Logically this would probably be done on their Cisco router but it might possibly be done on the Netgear (assuming that they have configuration access for the Netgear.)
Rick
