03-09-2016 01:23 AM - edited 03-05-2019 07:00 AM
Hello I have a problem with my router Cisco C881G-4G-GA-K9.
From my ISP I given only AP name: static.vivacell.am and dial-in number: *99#
I have made some initial configuration, but anyway I can't connect to ISP network.
This is startup config:
Current configuration : 1982 bytes
version 15.5
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
ethernet lmi ce
ip cef
no ipv6 cef
chat-script lte "" "AT!CALL" TIMEOUT 20 "OK"
chat-script HSPA "" "ATDT*98*1#" TIMEOUT 60 "CONNECT"
license udi pid C881G-4G-GA-K9 sn FCZ195392DZ
controller Cellular 0
lte modem link-recovery rssi onset-threshold -110
lte modem link-recovery monitor-timer 20
lte modem link-recovery wait-timer 10
lte modem link-recovery debounce-count 6
interface Cellular0
ip address negotiated
encapsulation slip
load-interval 30
dialer in-band
dialer idle-timeout 0
dialer string HSPA
dialer-group 1
no peer default ip address
async mode interactive
routing dynamic
interface Cellular1
no ip address
encapsulation slip
interface FastEthernet0
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface FastEthernet4
no ip address
shutdown
duplex auto
speed auto
interface Vlan1
ip address 192.168.10.1 255.255.255.0
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 Cellular0
dialer-list 1 protocol ip permit
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
line con 0
no modem enable
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
stopbits 1
line 3
script dialer HSPA
modem InOut
no exec
transport input all
transport output all
line 8
no exec
line vty 0 4
login
transport input none
scheduler allocate 20000 1000
end
This is output of "show cell 0 all" command:
Hardware Information
Modem Firmware Version = SWI9X15C_05.05.58.00
Modem Firmware built = 2015/03/04 21:30:23
Hardware Version = 1.0
Device Model ID: MC7304
Package Identifier ID: 1102029_9903299_MC7304_05.05.58.00_00_Cisco_005.010_000
International Mobile Subscriber Identity (IMSI) = 283058001571956
International Mobile Equipment Identity (IMEI) = 352761060675064
Integrated Circuit Card ID (ICCID) = 8937493808015719565
Mobile Subscriber Integrated Services
Digital Network-Number (MSISDN) =
Current Modem Temperature = 37 deg C
PRI SKU ID = 9903299, PRI version = 05.10, Carrier = 1
Profile Information
Profile 1 = INACTIVE* **
PDP Type = IPv4
Access Point Name (APN) = static.vivacell.am
Authentication = None
* - Default profile
** - LTE attach profile
Configured default profile for active SIM 0 is profile 1.
Data Connection Information
Profile 1, Packet Session Status = INACTIVE
Profile 2, Packet Session Status = INACTIVE
Profile 3, Packet Session Status = INACTIVE
Profile 4, Packet Session Status = INACTIVE
Profile 5, Packet Session Status = INACTIVE
Profile 6, Packet Session Status = INACTIVE
Profile 7, Packet Session Status = INACTIVE
Profile 8, Packet Session Status = INACTIVE
Profile 9, Packet Session Status = INACTIVE
Profile 10, Packet Session Status = INACTIVE
Profile 11, Packet Session Status = INACTIVE
Profile 12, Packet Session Status = INACTIVE
Profile 13, Packet Session Status = INACTIVE
Profile 14, Packet Session Status = INACTIVE
Profile 15, Packet Session Status = INACTIVE
Profile 16, Packet Session Status = INACTIVE
Network Information
Current System Time = Wed Mar 9 9:21:47 2016
Current Service Status = Normal
Current Service = Packet switched
Current Roaming Status = Home
Network Selection Mode = Automatic
Network = Vivacell-MTS
Mobile Country Code (MCC) = 283
Mobile Network Code (MNC) = 5
Packet switch domain(PS) state = Attached
Location Area Code (LAC) = 4101
Cell ID = 555859
Radio Information
Radio power mode = ON
Channel Number = 10638
Current Band = WCDMA 2100
Current RSSI(RSCP) = -45 dBm
Current ECIO = -4 dBm
Radio Access Technology(RAT) Preference = UMTS
Radio Access Technology(RAT) Selected = UMTS ( HSDPA HSUPA UMTS/WCDMA )
Modem Security Information
Active SIM = 0
SIM switchover attempts = 0
Card Holder Verification (CHV1) = Disabled
SIM Status = OK
SIM User Operation Required = None
Number of CHV1 Retries remaining = 3
GPS Information
GPS Info
GPS Feature: enabled
GPS Port Selected: Dedicated GPS port
GPS State: GPS disabled
SMS Information
Incoming Message Information
SMS stored in modem = 0
SMS archived since booting up = 0
Total SMS deleted since booting up = 0
Storage records allocated = 25
Storage records used = 0
Number of callbacks triggered by SMS = 0
Number of successful archive since booting up = 0
Number of failed archive since booting up = 0
Outgoing Message Information
Total SMS sent successfully = 0
Total SMS send failure = 0
Number of outgoing SMS pending = 0
Last Outgoing SMS Status = SUCCESS
Copy-to-SIM Status = 0x0
Send-to-Network Status = 0x0
Report-Outgoing-Message-Number:
Reference Number = 0
Result Code = 0x0
Diag Code = 0x0 0x0 0x0 0x0 0x0
SMS Archive URL =
Error Information
This command is not supported on this platform.
Modem Crashdump Information
Modem crashdump logging: off
Please help me to solve my problem.
03-14-2016 11:47 PM
The problem is solved.
08-19-2016 05:52 AM
Dear Ruzzana, how did you solve your problem?
