Can't connect via ssh through eth0/1 to my 1841 PLEASE HELP
andres-aceves1
I can connect to my router via eth0/0 with ssh but I cant with eth0/1. Please Help Me.
!This is the running config of the router: 192.168.0.254
!version 12.4
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
hostname RoSLPForaneas
boot-start-marker
boot-end-marker
security authentication failure rate 3 log
security passwords min-length 6
no logging buffered
logging console critical
enable secret 5 $1$6L9v$RFuiBkIxFbQ6tQfdUtYgv.
no aaa new-model
clock timezone MX -6
clock summer-time MX recurring
ip cef
ip inspect name SDM_LOW cuseeme
ip inspect name SDM_LOW dns
ip inspect name SDM_LOW ftp
ip inspect name SDM_LOW h323
ip inspect name SDM_LOW https
ip inspect name SDM_LOW icmp
ip inspect name SDM_LOW imap
ip inspect name SDM_LOW pop3
ip inspect name SDM_LOW netshow
ip inspect name SDM_LOW rcmd
ip inspect name SDM_LOW realaudio
ip inspect name SDM_LOW rtsp
ip inspect name SDM_LOW esmtp
ip inspect name SDM_LOW sqlnet
ip inspect name SDM_LOW streamworks
ip inspect name SDM_LOW tftp
ip inspect name SDM_LOW tcp
ip inspect name SDM_LOW udp
ip inspect name SDM_LOW vdolive
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
no ip bootp server
ip domain name ldimexico.com
ip name-server 8.8.8.8
ip name-server 8.8.4.4
crypto pki trustpoint TP-self-signed-3228746931
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-3228746931
revocation-check none
rsakeypair TP-self-signed-3228746931
username smontijo privilege 15 secret 5 $1$AyAK$A31GHTknqjQ70ABBAwNAu1
username esanchez privilege 15 secret 5 $1$IR59$QEwEH.hICUkGwrI0KSZHJ1
username carlosv privilege 15 secret 5 $1$eaDH$j3TqaTZojy7HBAqvIac8h/
username jmartinez privilege 15 secret 5 $1$avwi$2pU8NQsxECrLPEWTgeBpf/
ip ssh authentication-retries 5
crypto isakmp policy 10
encr 3des
authentication pre-share
group 2
crypto isakmp policy 11
encr 3des
hash md5
group 2
crypto isakmp key address 0.0.0.0 0.0.0.0
crypto ipsec transform-set vpn-transform esp-3des esp-sha-hmac
crypto ipsec transform-set vpn-transform1 esp-3des esp-md5-hmac
crypto dynamic-map vpn-dynamic 2
description San Isidro
set transform-set vpn-transform
set pfs group2
match address 102
crypto dynamic-map vpn-dynamic 3
description Americas
set pfs group2
match address 103
crypto dynamic-map vpn-dynamic 4
description Pablo Neruda
set pfs group2
match address 104
crypto dynamic-map vpn-dynamic 5
description Bodega Vallarta
set pfs group2
match address 105
crypto dynamic-map vpn-dynamic 6
description Palmas Vallarta
set pfs group2
match address 106
crypto dynamic-map vpn-dynamic 7
description Pipila Vallarta
set pfs group2
match address 107
crypto dynamic-map vpn-dynamic 8
description Aralias Vallarta
set pfs group2
match address 108
crypto dynamic-map vpn-dynamic 9
description Marina Vallarta
set pfs group2
match address 109
crypto dynamic-map vpn-dynamic 10
description Olas Vallarta
set pfs group2
match address 110
crypto dynamic-map vpn-dynamic 11
description Ajijic
set pfs group2
match address 111
crypto dynamic-map vpn-dynamic 12
description Colima
set pfs group2
match address 112
crypto map vpn-static 1 ipsec-isakmp dynamic vpn-dynamic
interface FastEthernet0/0
description $FW_OUTSIDE$$ETH-WAN$
ip address 100.1.130.141 255.255.255.0
ip verify unicast reverse-path
ip mtu 1492
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
no cdp enable
interface FastEthernet0/1
description $FW_INSIDE$$ETH-LAN$
ip address 192.168.0.254 255.255.255.0
ip nat inside
speed 100
full-duplex
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 100.1.130.5
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source route-map nonat interface FastEthernet0/0 overload
ip access-list extended sdm_fastethernet0/0_in
remark SDM_ACL Category=1
remark Auto generated by SDM for NTP (123) 200.23.51.205
permit udp host 200.23.51.205 eq ntp host 100.1.130.141 eq ntp
permit ahp any host 100.1.130.141
permit esp any host 100.1.130.141
permit udp any host 100.1.130.141 eq isakmp
permit udp any host 100.1.130.141 eq non500-isakmp
permit ip 192.168.26.0 0.0.0.255 192.168.0.0 0.0.0.255
permit ip 192.168.20.0 0.0.0.255 192.168.0.0 0.0.0.255
permit ip 192.168.12.0 0.0.0.255 192.168.0.0 0.0.0.255
permit ip 192.168.210.0 0.0.0.255 192.168.0.0 0.0.0.255
permit ip 192.168.19.0 0.0.0.255 192.168.0.0 0.0.0.255
permit ip 192.168.11.0 0.0.0.255 192.168.0.0 0.0.0.255
permit ip 192.168.8.0 0.0.0.255 192.168.0.0 0.0.0.255
permit ip 192.168.7.0 0.0.0.255 192.168.0.0 0.0.0.255
permit ip 192.168.27.0 0.0.0.255 192.168.0.0 0.0.0.255
permit ip 192.168.6.0 0.0.0.255 192.168.0.0 0.0.0.255
permit ip 192.168.37.0 0.0.0.255 192.168.0.0 0.0.0.255
remark SSH
permit tcp any any
ip access-list extended sdm_fastethernet0/0_in_100
permit ip any any
ip access-list extended sdm_fastethernet0/1_in
remark sshy
permit tcp any any
ip access-list extended sdm_fastethernet0/1_in_100
permit ip any any
access-list 100 remark auto generated by SDM firewall configuration
access-list 100 remark SDM_ACL Category=1
access-list 100 remark Auto generated by SDM for NTP (123) 200.23.51.205
access-list 100 permit udp host 200.23.51.205 eq ntp host 192.168.0.254 eq ntp
access-list 100 deny ip 100.1.130.0 0.0.0.255 any
access-list 100 deny ip host 255.255.255.255 any
access-list 100 deny ip 127.0.0.0 0.255.255.255 any
access-list 100 permit ip any any
access-list 101 remark auto generated by SDM firewall configuration
access-list 101 remark SDM_ACL Category=1
access-list 101 permit udp host 8.8.4.4 eq domain host 100.1.130.141
access-list 101 permit udp host 8.8.8.8 eq domain host 100.1.130.141
access-list 101 remark Auto generated by SDM for NTP (123) 200.23.51.205
access-list 101 permit udp host 200.23.51.205 eq ntp host 100.1.130.141 eq ntp
access-list 101 permit ahp any host 100.1.130.141
access-list 101 permit esp any host 100.1.130.141
access-list 101 permit udp any host 100.1.130.141 eq isakmp
access-list 101 permit udp any host 100.1.130.141 eq non500-isakmp
access-list 101 permit ip 192.168.26.0 0.0.0.255 192.168.0.0 0.0.0.255
access-list 101 permit ip 192.168.20.0 0.0.0.255 192.168.0.0 0.0.0.255
access-list 101 permit ip 192.168.12.0 0.0.0.255 192.168.0.0 0.0.0.255
access-list 101 permit ip 192.168.210.0 0.0.0.255 192.168.0.0 0.0.0.255
access-list 101 permit ip 192.168.19.0 0.0.0.255 192.168.0.0 0.0.0.255
access-list 101 permit ip 192.168.11.0 0.0.0.255 192.168.0.0 0.0.0.255
access-list 101 permit ip 192.168.8.0 0.0.0.255 192.168.0.0 0.0.0.255
access-list 101 permit ip 192.168.7.0 0.0.0.255 192.168.0.0 0.0.0.255
access-list 101 permit ip 192.168.27.0 0.0.0.255 192.168.0.0 0.0.0.255
access-list 101 permit ip 192.168.6.0 0.0.0.255 192.168.0.0 0.0.0.255
access-list 101 permit ip 192.168.37.0 0.0.0.255 192.168.0.0 0.0.0.255
access-list 101 deny ip 192.168.0.0 0.0.0.255 any
access-list 101 permit icmp any host 100.1.130.141 echo-reply
access-list 101 permit icmp any host 100.1.130.141 time-exceeded
access-list 101 permit icmp any host 100.1.130.141 unreachable
access-list 101 permit tcp any host 100.1.130.141 eq 443
access-list 101 permit tcp any host 100.1.130.141 eq 22
access-list 101 permit tcp any host 100.1.130.141 eq cmd
access-list 101 deny ip 10.0.0.0 0.255.255.255 any
access-list 101 deny ip 172.16.0.0 0.15.255.255 any
access-list 101 deny ip 192.168.0.0 0.0.255.255 any
access-list 101 deny ip 127.0.0.0 0.255.255.255 any
access-list 101 deny ip host 255.255.255.255 any
access-list 101 deny ip host 0.0.0.0 any
access-list 101 deny ip any any log
access-list 102 remark San Isidro
access-list 102 remark SDM_ACL Category=20
access-list 102 permit ip 192.168.0.0 0.0.0.255 192.168.37.0 0.0.0.255
access-list 102 deny ip 192.168.0.0 0.0.0.255 any
access-list 103 remark Americas
access-list 103 remark SDM_ACL Category=20
access-list 103 permit ip 192.168.0.0 0.0.0.255 192.168.6.0 0.0.0.255
access-list 103 deny ip 192.168.0.0 0.0.0.255 any
access-list 104 remark Pablo Neruda
access-list 104 permit ip 192.168.0.0 0.0.0.255 192.168.27.0 0.0.0.255
access-list 104 deny ip 192.168.0.0 0.0.0.255 any
access-list 105 remark Bodega Vallarta
access-list 105 permit ip 192.168.0.0 0.0.0.255 192.168.7.0 0.0.0.255
access-list 105 deny ip 192.168.0.0 0.0.0.255 any
access-list 106 remark Palmas Vallarta
access-list 106 remark SDM_ACL Category=20
access-list 106 permit ip 192.168.0.0 0.0.0.255 192.168.8.0 0.0.0.255
access-list 106 deny ip 192.168.0.0 0.0.0.255 any
access-list 107 remark Pipila Vallarta
access-list 107 remark SDM_ACL Category=20
access-list 107 permit ip 192.168.0.0 0.0.0.255 192.168.11.0 0.0.0.255
access-list 107 deny ip 192.168.0.0 0.0.0.255 any
access-list 108 remark Aralias Vallarta
access-list 108 permit ip 192.168.0.0 0.0.0.255 192.168.19.0 0.0.0.255
access-list 108 deny ip 192.168.0.0 0.0.0.255 any
access-list 109 remark Marina Vallarta
access-list 109 permit ip 192.168.0.0 0.0.0.255 192.168.210.0 0.0.0.255
access-list 109 deny ip 192.168.0.0 0.0.0.255 any
access-list 110 remark Olas Vallarta
access-list 110 permit ip 192.168.0.0 0.0.0.255 192.168.12.0 0.0.0.255
access-list 110 deny ip 192.168.0.0 0.0.0.255 any
access-list 111 remark Ajijic
access-list 111 permit ip 192.168.0.0 0.0.0.255 192.168.20.0 0.0.0.255
access-list 111 deny ip 192.168.0.0 0.0.0.255 any
access-list 112 remark Colima
access-list 112 permit ip 192.168.0.0 0.0.0.255 192.168.26.0 0.0.0.255
access-list 112 deny ip 192.168.0.0 0.0.0.255 any
access-list 113 remark auto generated by SDM firewall configuration
access-list 113 remark SDM_ACL Category=1
access-list 113 deny ip 100.1.130.0 0.0.0.255 any
access-list 113 deny ip host 255.255.255.255 any
access-list 113 deny ip 127.0.0.0 0.255.255.255 any
access-list 113 permit ip any any
access-list 114 remark auto generated by SDM firewall configuration
access-list 114 remark SDM_ACL Category=1
access-list 114 permit udp host 8.8.4.4 eq domain host 100.1.130.141
access-list 114 permit udp host 8.8.8.8 eq domain host 100.1.130.141
access-list 114 remark Auto generated by SDM for NTP (123) 200.23.51.205
access-list 114 permit udp host 200.23.51.205 eq ntp host 100.1.130.141 eq ntp
access-list 114 permit ahp any host 100.1.130.141
access-list 114 permit esp any host 100.1.130.141
access-list 114 permit udp any host 100.1.130.141 eq isakmp
access-list 114 permit udp any host 100.1.130.141 eq non500-isakmp
access-list 114 permit ip 192.168.26.0 0.0.0.255 192.168.0.0 0.0.0.255
access-list 114 permit ip 192.168.20.0 0.0.0.255 192.168.0.0 0.0.0.255
access-list 114 permit ip 192.168.12.0 0.0.0.255 192.168.0.0 0.0.0.255
access-list 114 permit ip 192.168.210.0 0.0.0.255 192.168.0.0 0.0.0.255
access-list 114 permit ip 192.168.19.0 0.0.0.255 192.168.0.0 0.0.0.255
access-list 114 permit ip 192.168.11.0 0.0.0.255 192.168.0.0 0.0.0.255
access-list 114 permit ip 192.168.8.0 0.0.0.255 192.168.0.0 0.0.0.255
access-list 114 permit ip 192.168.7.0 0.0.0.255 192.168.0.0 0.0.0.255
access-list 114 permit ip 192.168.27.0 0.0.0.255 192.168.0.0 0.0.0.255
access-list 114 permit ip 192.168.6.0 0.0.0.255 192.168.0.0 0.0.0.255
access-list 114 permit ip 192.168.37.0 0.0.0.255 192.168.0.0 0.0.0.255
access-list 114 deny ip 192.168.0.0 0.0.0.255 any
access-list 114 permit icmp any host 100.1.130.141 echo-reply
access-list 114 permit icmp any host 100.1.130.141 time-exceeded
access-list 114 permit icmp any host 100.1.130.141 unreachable
access-list 114 deny ip 10.0.0.0 0.255.255.255 any
access-list 114 deny ip 172.16.0.0 0.15.255.255 any
access-list 114 deny ip 192.168.0.0 0.0.255.255 any
access-list 114 deny ip 127.0.0.0 0.255.255.255 any
access-list 114 deny ip host 255.255.255.255 any
access-list 114 deny ip host 0.0.0.0 any
access-list 114 deny ip any any log
access-list 115 remark auto generated by SDM firewall configuration
access-list 115 remark SDM_ACL Category=1
access-list 115 permit udp host 8.8.4.4 eq domain host 100.1.130.141
access-list 115 permit udp host 8.8.8.8 eq domain host 100.1.130.141
access-list 115 remark Auto generated by SDM for NTP (123) 200.23.51.205
access-list 115 permit udp host 200.23.51.205 eq ntp host 100.1.130.141 eq ntp
access-list 115 permit ahp any host 100.1.130.141
access-list 115 permit esp any host 100.1.130.141
access-list 115 permit udp any host 100.1.130.141 eq isakmp
access-list 115 permit udp any host 100.1.130.141 eq non500-isakmp
access-list 115 permit ip 192.168.26.0 0.0.0.255 192.168.0.0 0.0.0.255
access-list 115 permit ip 192.168.20.0 0.0.0.255 192.168.0.0 0.0.0.255
access-list 115 permit ip 192.168.12.0 0.0.0.255 192.168.0.0 0.0.0.255
access-list 115 permit ip 192.168.210.0 0.0.0.255 192.168.0.0 0.0.0.255
access-list 115 permit ip 192.168.19.0 0.0.0.255 192.168.0.0 0.0.0.255
access-list 115 permit ip 192.168.11.0 0.0.0.255 192.168.0.0 0.0.0.255
access-list 115 permit ip 192.168.8.0 0.0.0.255 192.168.0.0 0.0.0.255
access-list 115 permit ip 192.168.7.0 0.0.0.255 192.168.0.0 0.0.0.255
access-list 115 permit ip 192.168.27.0 0.0.0.255 192.168.0.0 0.0.0.255
access-list 115 permit ip 192.168.6.0 0.0.0.255 192.168.0.0 0.0.0.255
access-list 115 permit ip 192.168.37.0 0.0.0.255 192.168.0.0 0.0.0.255
access-list 115 deny ip 192.168.0.0 0.0.0.255 any
access-list 115 permit icmp any host 100.1.130.141 echo-reply
access-list 115 permit icmp any host 100.1.130.141 time-exceeded
access-list 115 permit icmp any host 100.1.130.141 unreachable
access-list 115 deny ip 10.0.0.0 0.255.255.255 any
access-list 115 deny ip 172.16.0.0 0.15.255.255 any
access-list 115 deny ip 192.168.0.0 0.0.255.255 any
access-list 115 deny ip 127.0.0.0 0.255.255.255 any
access-list 115 deny ip host 255.255.255.255 any
access-list 115 deny ip host 0.0.0.0 any
access-list 115 deny ip any any log
access-list 151 remark SDM_ACL Category=18
access-list 151 deny ip 192.168.0.0 0.0.0.255 192.168.210.0 0.0.0.255
access-list 151 deny ip 192.168.0.0 0.0.0.255 192.168.37.0 0.0.0.255
access-list 151 deny ip 192.168.0.0 0.0.0.255 192.168.6.0 0.0.0.255
access-list 151 deny ip 192.168.0.0 0.0.0.255 192.168.27.0 0.0.0.255
access-list 151 deny ip 192.168.0.0 0.0.0.255 192.168.7.0 0.0.0.255
access-list 151 deny ip 192.168.0.0 0.0.0.255 192.168.8.0 0.0.0.255
access-list 151 deny ip 192.168.0.0 0.0.0.255 192.168.11.0 0.0.0.255
access-list 151 deny ip 192.168.0.0 0.0.0.255 192.168.19.0 0.0.0.255
access-list 151 deny ip 192.168.0.0 0.0.0.255 192.168.20.0 0.0.0.255
access-list 151 deny ip 192.168.0.0 0.0.0.255 192.168.26.0 0.0.0.255
access-list 151 deny ip 192.168.0.0 0.0.0.255 192.168.12.0 0.0.0.255
access-list 151 permit ip any any
snmp-server community draco RO
snmp-server community m0n1t0r30 RO
snmp-server enable traps tty
no cdp run
route-map nonat permit 10
match ip address 151
control-plane
banner login ^CCCAuthorized access only!
Disconnect IMMEDIATELY if you are not an authorized user!^C
line con 0
login local
transport output telnet
line aux 0
login local
stopbits 1
speed 115200
flowcontrol hardware
line vty 0 4
privilege level 15
logging synchronous
login local
transport input telnet ssh
transport output ssh
line vty 5 15
privilege level 15
login local
transport input ssh
scheduler allocate 4000 1000
ntp clock-period 17179959
ntp server 200.23.51.205
end
Ben Gartland
I'd start by using an access list to debug tcp 22 and see if the traffic arrives at the WAN interface..
access-list 199 permit tcp any any eq 22
debug ip packet 199 detail
then SSH to the router whilst monitoring the debug.  If no packets seen,  then likely blocked before getting to router.
Best practice is to replace public IP addresses on configs before pasting them here,  you can leave the private addresses intact,  they are fine.
Ben
philipdurandt
I'm not seeing your ACL linked to any of your interfaces.
You might want to look into that.
Then, I don't know how your network layout looks or how you connect to the router for that matter so let's ask this:
  1. What IP do you use to SSH to FA0/0?
  2. What IP do you use to SSH to FA0/1?
  3. Can you ping both IPs?
  4. What happens if you connect your pc directly to FA0/1, make your IP 192.168.0.1/24 and try SSH to 192.168.0.254? Does that work?
jonathanlunt
This isn't an answer to your question, but please take note from this.
You shouldn't post anything with public addresses in, it should at least be replaced by 100.X.X.X if not X.X.X.X completely.
I hope someone can answer your question for you.
