Can't login to Quick Setup Wizard in ISR 1100
When I login to Router http://192.168.1.1/webui/#/dayZeroRouting
it's directly switched to http://192.168.1.1/webui/#/dashboard
Can you please advice to make as main page.
pieterh
 http://192.168.1.1/webui/#/dayZeroRouting  ???
-> this is for out-of-the box configuration
your redirection to the dashboard indicates dayzero setup has already be done
-> wipe the config (factory reset) and you can start fresh
pieterh
Thanks dear pieterh for your help which guiding me to Quick Setup Wizard.
