Can't ping across IPSEC protected GRE tunnel with multiple VRFs
nfrick
I was hoping someone else has done this sort of configuration and can help me.  I have configured a GRE tunnel with IPSEC tunnel protection between 2921 15.0(1r)M16 and 2951 15.0(1r)M16 routers.  When I remove IPSEC from the tunnel I can ping each destination from either router, so I know GRE is set up correctly.  However as soon as I add IPSEC I can no longer ping each side.  The ISAKMP SA state on each router is QM_IDLE and each has an active IPSEC inbound esp sa and outbound esp sa.
I've included the relevant config components off each router along with the results of show crypto session for the tunnel interface.  I have done debugging on each side for crypto isakmp, crypto ipsec, and tunnel protection but don't see any obvious issues.  I'm not sure if it is a VRF issue or not since I can ping when the tunnel protection is disabled.  What am I missing here?  Any help anyone can give me would be very welcome.
Router 1:
ip vrf TW
 rd 203:2
ip vrf p2p
 rd 101:1
crypto keyring TW vrf TW
  pre-shared-key address 64.128.130.202 key
crypto isakmp policy 10
 encr aes 256
 hash md5
 authentication pre-share
 group 2
crypto isakmp policy 20
 encr aes 256
 hash md5
crypto isakmp nat keepalive 20
crypto isakmp profile TW
   vrf TW
   keyring TW
   match identity address 64.128.130.202 255.255.255.255 TW
   keepalive 20 retry 2
   local-address GigabitEthernet0/0/0
crypto ipsec transform-set p2pstrong esp-3des esp-md5-hmac
 mode transport
crypto ipsec fragmentation after-encryption
crypto ipsec profile p2psecure
 set security-association lifetime seconds 86400
 set transform-set p2pstrong
 set isakmp-profile TW
interface Tunnel1
 bandwidth 20000
 ip vrf forwarding p2p
 ip address 10.0.4.1 255.255.254.0
 no ip unreachables
 no ip proxy-arp
 ip mtu 1400
 ip virtual-reassembly in
 ip tcp adjust-mss 1360
 ip policy route-map TW-set-sourced
 tunnel source GigabitEthernet0/0/0
 tunnel destination 64.128.130.202
 tunnel vrf TW
 tunnel protection ipsec profile p2psecure
interface GigabitEthernet0/0/0
 ip vrf forwarding TW
 ip address 64.128.71.86 255.255.255.252
 duplex auto
 speed auto
ip route vrf TW 0.0.0.0 0.0.0.0 64.128.71.85
ip route vrf p2p 10.0.4.2 255.255.255.255 Tunnel1
Interface: Tunnel1
Profile: TW
Session status: UP-ACTIVE
Peer: 64.128.130.202 port 500
  IKEv1 SA: local 64.128.71.86/500 remote 64.128.130.202/500 Active
  IPSEC FLOW: permit 47 host 64.128.71.86 host 64.128.130.202
        Active SAs: 2, origin: crypto map
Router 2:
ip vrf TW
 rd 201:1
ip vrf p2p
 rd 202:3
  pre-shared-key address 64.128.71.86 key
 encr aes 256
 hash md5
 group 2
 encr aes 256
 hash md5
crypto isakmp keepalive 20 3
crypto isakmp profile test2
   vrf global
   keyring TW
   match identity address 64.128.71.86 255.255.255.255 TW
   local-address GigabitEthernet0/2
 mode transport
 set isakmp-profile test2
interface Tunnel1
 bandwidth 20000
 ip address 10.0.4.2 255.255.254.0
 no ip unreachables
 no ip proxy-arp
 ip mtu 1400
 tunnel source GigabitEthernet0/2
 tunnel destination 64.128.71.86
 tunnel vrf TW
interface GigabitEthernet0/2
 ip address 64.128.130.202 255.255.255.252
 duplex auto
 speed auto
Interface: Tunnel1
Profile: test2
Peer: 64.128.71.86 port 500
  Session ID: 0
  IKEv1 SA: local 64.128.130.202/500 remote 64.128.71.86/500 Active
  IPSEC FLOW: permit 47 host 64.128.130.202 host 64.128.71.86
Let me see if I have understand:
The inside vrf is the p2p   10.0.4.1 -> 10.0.4.2 (inside packet of ipsec)
The front door vrf is TW  64.128.71.86 -> 64.128.130.202 (outside encrypted traffic)
You can "ping vrf TW 64.128.130.202" , that is OK!
You can not "ping vrf TW 10.0.4.2", that is also OK!
Try this:
Remove the static:
(as 10.0.4.2 is a direct access on Tunnel you do not need a route)
and add:
ip route vrf p2p 0.0.0.0 0.0.0.0 10.0.4.2 (router 1)
ip route vrf p2p 0.0.0.0 0.0.0.0 10.0.4.1 (router 2)
Try to ping some hosts on p2p vrf
And also:
try remove "vrf TW" on "crypto isakmp profile TW" (router 1)
and "vrf global" on "crypto isakmp profile test2" (router 2)
Pedro Lereno
Pedro Lereno
Did you ping inside vrf TW?
What is the result of debug ip icmp?
Pedro Lereno
Thanks for replying, I am pinging within the p2p vrf.  I can ping the tunnel source and destination (eg. public IP addresses) on the TW vrf.  Here are the results of pinging each tunnel IP address from router 2 on both vrfs.  I had debug ip icmp on for all of these, the only entries are from ping vrf p2p 10.0.4.2 (which is this router).
VHD-FL-Spoke#ping vrf TW 10.0.4.2
Sending 5, 100-byte ICMP Echos to 10.0.4.2, timeout is 2 seconds:
Success rate is 0 percent (0/5)
VHD-FL-Spoke#ping vrf TW 10.0.4.1
Sending 5, 100-byte ICMP Echos to 10.0.4.1, timeout is 2 seconds:
VHD-FL-Spoke#ping vrf p2p 10.0.4.2
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/4 ms
VHD-FL-Spoke#ping vrf p2p 10.0.4.1
*Sep 10 17:47:26.996: ICMP: echo reply sent, src 10.0.4.2, dst 10.0.4.2, topology BASE, dscp 0 topoid 4
*Sep 10 17:47:26.996: ICMP: echo reply rcvd, src 10.0.4.2, dst 10.0.4.2, topology BASE, dscp 0 topoid 4
*Sep 10 17:47:27.000: ICMP: echo reply sent, src 10.0.4.2, dst 10.0.4.2, topology BASE, dscp 0 topoid 4
*Sep 10 17:47:27.000: ICMP: echo reply rcvd, src 10.0.4.2, dst 10.0.4.2, topology BASE, dscp 0 topoid 4
Edit: If I disable IPSEC, I can successfully do a ping vrf p2p 10.0.4.1 from this router.  But I need IPSEC on.
Try this:
Remove the static:
and add:
And also:
Pedro Lereno
Pedro,
Thank you very much for your help.  I've made these changes and everything is working perfectly now.
