04-08-2011 03:28 AM - edited 03-04-2019 12:01 PM
I have an GRE Tunnel across my head office and remote site with multiple subnets using cisco 1841 routers.I can ping most of the devices on the remote side, but I can not ping certain devices. These devices respond to ping requests on the local LAN, but not through the WAN link. If I change the IP of device than it start responding. I am using same gateway and mask on these devices. Any ideas. The remote site is running classic STP on switches with distribution switch being the root bridge. Any suggestions/ ideas?
04-08-2011 04:08 AM
Is this just a regular GRE tunnel or is it GRE with IPSec or something ? Are there any access lists associated with the tunnel on either end? Are you running any routing protocol over the tunnel? After you change the address and a device starts to respond if you change it back to the original address does it respond still?
If we knew these things perhaps we could give you a better answer.
Rick
04-08-2011 05:43 AM
Its a regular GRE and OSPF is running on it. No access list associated either with physical interface and with Tunnel interface.
The device starts responding to ping rather randomly if I change the address it respond and if I change to its original address it sometimes respond for certain time and than again stop responding.
I have about 200 machine in that subnet and only 22 respond to ping addresses continously. From remote router I can ping every address but if I ping from my head office router I can get response from certain IP addresses.
After running debug ip packet on remote router I get following response
Apr 8 22:27:11.409: IP: tableid=0, s=172.16.1.3 (Tunnel150), d=172.16.10.15 (FastEthernet0/0.1), routed via RIB
Apr 8 22:27:11.409: IP: s=172.16.1.3 (Tunnel150), d=172.16.10.15 (FastEthernet0/0.1), g=172.16.10.15, len 100, forward
Apr 8 22:27:11.413: IP: s=172.16.1.3 (Tunnel150), d=172.16.10.15 (FastEthernet0/0.1), len 100, encapsulation failed
It seems router loses layer 2 address rather randomly
-Taufeeq
04-08-2011 06:13 AM
can u check the arp entry on the router, follow these steps:
show ip arp 172.16.10.15
ping 172.16.10.15
04-08-2011 10:24 PM
Protocol Address Age (min) Hardware Addr Type Interface
Internet 172.16.10.15 0 0015.6057.1bbb ARPA FastEthernet0/0.1
at remote router
