Can't Ping other routers in Frame-Relay
springxdxml
Hello
I have 3 routers connected through a frame-relay switch in GNS3.
This is the config for the 3 routers
R1(config)#int s0/0
R1(config-if)#no shut
R1(config-if)#encapsulation frame-relay
R1(config)#int s0/0.1 multipoint
R1(config-subif)#ip address 192.168.1.1 255.255.255.248
R1(config-subif)#frame-relay map ip 192.168.1.2 101 broadcast
R1(config-subif)#frame-relay map ip 192.168.1.3 102 broadcast
R2(config)#int s0/0
R2(config-if)#no shut
R2(config-if)#encapsulation frame-relay
R2(config)#int s0/0.1 multipoint
R2(config-subif)#ip address 192.168.1.2 255.255.255.248
R2(config-subif)#frame-relay map ip 192.168.1.1 201 broadcast
R3(config)#int s0/0
R3(config-if)#no shut
R3(config-if)#encapsulation frame-relay
R3(config)#int s0/0.1 multipoint
R3(config-subif)#ip address 192.168.1.3 255.255.255.248
R3(config-subif)#frame-relay map ip 192.168.1.1 203 broadcas
When using the "show frame-relay map" command on all 3 routers, i get ACTIVE. The problem is I can't ping anyone.
Any ideas as to what I can do to make them ping each other?
springxdxml
Problem solved. R2 and r3 Ip addresses were swtiched
