Can't ping routers across point-to-point frame-relay
paquinjrm
'evening,
  Really basic setup.  Designed with Packet Tracer, trying to ping routers across a point-to-point frame-relay.  I've designed this according to three different training sources who all say the same thing.  Yet, all pings failed.
The shows:
R1
R1#copy run st
Destination filename [startup-config]?
Building configuration...
[OK]
R1#show run
Current configuration : 883 bytes
version 12.2
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname R1
no ip domain-lookup
interface FastEthernet0/0
 no ip address
 duplex auto
 speed auto
 shutdown
interface FastEthernet0/1
 no ip address
 duplex auto
 speed auto
 shutdown
interface Serial1/0
 no ip address
 encapsulation frame-relay
interface Serial1/0.12 point-to-point
 ip address 192.168.12.1 255.255.255.0
 frame-relay interface-dlci 102
interface Serial1/0.13 point-to-point
 ip address 192.168.13.1 255.255.255.0
 frame-relay interface-dlci 103
ip classless
end
R1#show frame-relay lmi
LMI Statistics for interface Serial1/0 (Frame Relay DTE) LMI TYPE = CISCO
 Invalid Unnumbered info 0      Invalid Prot Disc 0
 Invalid dummy Call Ref 0       Invalid Msg Type 0
 Invalid Status Message 0       Invalid Lock Shift 0
 Invalid Information ID 0       Invalid Report IE Len 0
 Invalid Report Request 0       Invalid Keep IE Len 0
 Num Status Enq. Sent 638       Num Status msgs Rcvd 638
 Num Update Status Rcvd 0       Num Status Timeouts 16
LMI Statistics for interface Serial1/0.12 (Frame Relay DTE) LMI TYPE = CISCO
 Num Status Enq. Sent 0         Num Status msgs Rcvd 0
LMI Statistics for interface Serial1/0.13 (Frame Relay DTE) LMI TYPE = CISCO
R1#show frame-relay map
Serial1/0.12 (up): point-to-point dlci, dlci 102, broadcast, status defined, active
Serial1/0.13 (up): point-to-point dlci, dlci 103, broadcast, status defined, active
R1#show frame-relay pvc
PVC Statistics for interface Serial1/0 (Frame Relay DCE)
DLCI = 102, DLCI USAGE = LOCAL, PVC STATUS = ACTIVE, INTERFACE = Serial1/0.12
input pkts 14055       output pkts 32795        in bytes 1096228
out bytes 6216155      dropped pkts 0           in FECN pkts 0
in BECN pkts 0         out FECN pkts 0          out BECN pkts 0
in DE pkts 0           out DE pkts 0
out bcast pkts 32795   out bcast bytes 6216155
DLCI = 103, DLCI USAGE = LOCAL, PVC STATUS = ACTIVE, INTERFACE = Serial1/0.13
R2
R2#SHOW RUN
Current configuration : 772 bytes
version 12.2
hostname R2
no ip domain-lookup
interface Serial1/0
 no ip address
 ip address 192.168.12.2 255.255.255.0
 frame-relay interface-dlci 201
ip classless
end
R2#show fr map
Serial1/0.12 (up): point-to-point dlci, dlci 201, broadcast, status defined, active
R2#show fr pvc
PVC Statistics for interface Serial1/0 (Frame Relay DTE)
DLCI = 201, DLCI USAGE = LOCAL, PVC STATUS = ACTIVE, INTERFACE = Serial1/0.12
R2#show fr lmi
 Num Status Enq. Sent 679       Num Status msgs Rcvd 678
R3
R3#show run
version 12.2
hostname R3
interface Serial1/0
 no ip address
 ip address 192.168.13.2 255.255.255.0
 frame-relay interface-dlci 301
ip classless
end
R3#show fr map
Serial1/0.13 (up): point-to-point dlci, dlci 301, broadcast, status defined, active
R3#show fr lmi
 Num Status Enq. Sent 703       Num Status msgs Rcvd 702
R3#show fr pvc
DLCI = 301, DLCI USAGE = LOCAL, PVC STATUS = ACTIVE, INTERFACE = Serial1/0.13
  Any input would really be appreciated.
0 Replies 0
