Can't ping with BGP in GNS3 lab environment
s.quirion
Community Member
Here is a section of my BGP lab inside GNS3:
My issue is not being able to ping anything on R5 from R2 even though R2 is recieving the routes from R5 and has placed them in it's routing table.
Thanks in advance for any help or advice!
-Steve
R2#sho ip bgp
BGP table version is 5, local router ID is 10.1.96.2
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
              r RIB-failure, S Stale
Origin codes: i - IGP, e - EGP, ? - incomplete
   Network          Next Hop            Metric LocPrf Weight Path
* i150.1.50.0/24    10.1.36.2                0    700      0 777 711 911 ?
*>                  10.1.24.2                              0 777 911 ?
* i150.2.50.0/24    10.1.36.2                0    700      0 777 711 911 ?
* i200.50.2.0       10.1.36.2                0    700      0 777 711 i
*>                  10.1.24.2                              0 777 911 711 i
* i200.60.2.0       10.1.36.2                0    700      0 777 711 i
R2#sho ip route
Gateway of last resort is not set
B    200.50.2.0/24 [20/0] via 10.1.24.2, 00:23:17
B    200.60.2.0/24 [20/0] via 10.1.24.2, 00:23:17
     10.0.0.0/24 is subnetted, 3 subnets
C       10.1.12.0 is directly connected, Serial0/0
C       10.1.24.0 is directly connected, Serial0/2
C       10.1.96.0 is directly connected, Serial0/1
     150.1.0.0/24 is subnetted, 1 subnets
B       150.1.50.0 [20/0] via 10.1.24.2, 00:23:17
     150.2.0.0/24 is subnetted, 1 subnets
B       150.2.50.0 [20/0] via 10.1.24.2, 00:23:17
R2#ping 150.1.50.1
Sending 5, 100-byte ICMP Echos to 150.1.50.1, timeout is 2 seconds:
Success rate is 0 percent (0/5)
R2#trace 150.1.50.1
Tracing the route to 150.1.50.1
  1 10.1.24.2 52 msec 44 msec 24 msec
  2  *  *  *
        ^ so the ping make it to the next AS but stops there
R2#sho run
Building configuration...
Current configuration : 1183 bytes
version 12.4
hostname R2
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
ip cef
no ip domain lookup
ip domain name lab.local
interface Serial0/0
ip address 10.1.12.2 255.255.255.0
clock rate 64000
interface Serial0/1
ip address 10.1.96.2 255.255.255.0
clock rate 64000
interface Serial0/2
ip address 10.1.24.1 255.255.255.0
clock rate 64000
router bgp 5500
no synchronization
bgp log-neighbor-changes
neighbor 10.1.12.1 remote-as 5500
neighbor 10.1.12.1 next-hop-self
neighbor 10.1.24.2 remote-as 777
neighbor 10.1.96.1 remote-as 5500
no auto-summary
no ip http server
no ip http secure-server
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
line vty 0 4
login
end
AhmedSonba
Level 5
Level 5
You will need to enable some sort of internal routing protocol on your routers if they were in the same AS or configure static routing between them in case they were in different Autonomous Systems.
You can refer to the following links for more information about the BGP configuration
http://www.cisco.com/en/US/tech/tk365/technologies_configuration_example09186a008009456d.shtml#directlyconnected
http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a00800c95bb.shtml
Hope it will help
Ahmed Sonba
AhmedSonba
Level 5
Level 5
Hope it will help
Ahmed Sonba
Thank you very much for your response, I was able to get the lab to work by adding:
R2
ip route 10.1.99.1 255.255.255.255 10.1.24.2 2
R5
ip route 10.1.24.1 255.255.255.255 10.1.99.2 2
So now my question is, why? R2 knows the way to get to R5 is by going to R4, so when R4 gets the ping why does it not forward it to where it needs to go? Furthermore R2 has marked the route with a ">" which says "this is a valid route".
In real world BGP environments, is it not a common thing for a router to be connected to autonomous systems that are not directly connected?
Thanks again, I may just be a little trown off after my brain has only thought RIP, OSPF, and EIGRP for my entire Cisco carrer.
-Steve
cadet alain
does R5 has a route for the 10.1.24.0  network ?
either put a network command or redistribute this subnet into BGP in AS 5500(R2) or  use a static route pointing to ISP router for this network
Regards.
Alain
neil.caughey
Community Member
I ran into the same issue on GNS3
I think the actual reason your pings will not work is due to the source of the icmp packet.
By default the packet will send from the ip on the physical interface going out to the ISP (whereas the remote router you ping only knows the bgp advertised subnet, not the subnet of the WAN link)
So you can add a static route to the respective subnets if you want, but a more secure option would be to specify the source of of the ping as the interface the remote router knows via BGP.
This is what I did with no extra static routes added.
I realise this post is v old by now, just adding this for anyone who stumbles across it in future.
