Cannot access Microsoft Site with Cisco G.SHDSL router
zumo007
I use cisco router 2821. I connect internet by use WIC-1SHDSL-V3 card(G.SHDSL). The connection was success, I can access to any web sites except Microsoft site such as http://www.hotmail.com When I request http://www.hotmail.com, the main page can display and allow me to login. Then, I continue to login, it was not success and show page cannot display.
These were the information for our router
- IOS version =c2800nm-spservicesk9-mz.124-15.XZ.bin
Thank in advance
rkhalil
May be the problem is of your ISP or of MTU configuration of the ATM controller.., check using a ping or traceroute and paste the output here..
Raul
stephen.stack
Level 4
Level 4
Apply this to your router.
On your inside ethernet interface.
interface fa0/0
ip tcp adjust-mss 1452
! on your dialer interface
interface dialer 0
ip mtu 1492
That should fix it.... a really old problem
HTH - Please rate if it does.
Stephen
========================== http://www.rconfig.com A free, open source network device configuration management tool, customizable to your needs! - Always vote on an answer if you found it helpful
