Disaster Recovery Solution with Duplicate / Floating IP Subnet
Wilson Samuel
Level 7
Level 7
I have a situation where I need to have a Disaster Recovery Site with same IP Subnet that is of the main site across a WAN link using Routers.
I'm not sure of it now and not able to recall the name of the technology about it.
Any help would be greatly appreciated.
Kind Regards,
Wilson Samuel
avillalva
Hi Wilson,
The technology you are after is called L2tpv3(Layer 2 tunnelling protocol V3). It will allow you to have the same IP subnet accross WAN links.
Hope that helps,
Andres
Hi Andres,
Thanks a lot, your post really helped me.
